Question about Scubapro MK25/G250 Hp Regulator
My problem is i don't have anymore teeth in my mouth i can not bite the regulator if i dive, my regulator will detached to my mouth and i can not proceed with my work as underwater assistment.
Posted by www_aris_amp on
Dan Jacobs
    Renaissance:
    An user who is expert in 3 categories / brands.
  • 808 Answers
They sell aftermarket mouth pieces that you warm in water once soft and pliable you bite down it takes shape to your bite plate which is further back in your mouth and can not be pulled out .
Posted on May 16, 2014
What can i use for pain around my teeth and gum?
get to a dentist for gum and teeth repair before you get an infection in the gums and the loose teeth fall out
Oct 21, 2017 | The Health & Beauty
Could a nonessential corrective dentistry herts specialist change the length of my teeth?
The orthodontist might propose a blending of corrective dentistry herts and lacquers or crown stretching. Encountered orthodontists work with a system of different experts who can cooperate to attain the effects you need.
Dec 03, 2013 | Computers & Internet
I grind my teeth at night. what kind of mouth guard can I use to help this problem?
You should use a nocturnal bite plate (or bite splint) to prevent tooth damage.
Apr 29, 2013 | Health & Beauty
What is a boil and bite mouth protector?
A boil and bite mouth protector is a mouthguard that is bought from a sporting store. It is better than a stock mouth protector as it is more personalized. It is made from thermoplastic and then put in hot water to soften and put in the mouth to get the shape of the teeth.
What is the best mouth guard
There are numerous types of mouth guards that you can choose from. The best type is the custom made mouth guards that you get at the dentist office. However, they are more expensive. If you want a less expensive mouth guard, I'd go with the boil and bite mouth guards because they adjust to your teeth very well. You can read more information about mouth guards on this website: http://dentistry.about.com/od/basicdentalcare/f/mouthguardtype.htm
Oct 16, 2012 | Century Shock Doctor Gel Max
Do I need a mouth piece?
The mouth piece is very important for an amateur boxer aswell as a professional one. I suggest you not to take any risk with practicingwithout a mouth piece in order to avoid losing or damaging your teeth. I'veseen boxers around my making bad call with this case and paying lots of moneyon dental treatments and even after that the teeth don't go back to the samecondition, it's not a game and you should always be protected as much as youcan.
Jul 23, 2012 | Boxing
Guidelines to Scuba Regulator Purchase
The scuba regulator is employed in an open-circuit scuba set. Said scuba equipment reduces high air pressure conveyed by the diving cylinder to the first stage and feeds breathable gas to the diver through the second stage's mouthpiece. Also called pressure regulator or demand regulator, the scuba equipment is one of the essentials to diving that determines breathing quality and inhalation effort during the dive. But given the different types of regulators and the pertinent design of its first and second stage components, how should a neophyte diver - or even a seasoned diver at that, choose a scuba regulator that incorporates user adjustment and delivers a venturi-assisted air flow in its features? Consider your diving purpose and frequency. Better yet, take note of the following criteria to guide you in your purchase: 1. The Scuba Regulator's Mouthpiece. Check the specifications if the regulator is outfitted with a patented orthodontic mouthpiece. This implies that it is ergonomically-designed to accommodate an overbite or underbite by the human mouth. An ergonomic mouthpiece helps reduce fatigue in the mouth and jaw area, particularly in the cruise of lower depths and extended dives. 2. User Adjustment Settings. There are optimally-designed scuba regulators that are outfitted with adjustment levers to therefore allow divers to finetune valve settings in order to provide the least possible inhalation effort throughout the dive. One notable scuba equipment is the Aeris AT 400 Pro Regulator that is equipped with an adjustable second stage. 3. Weight of the Scuba Regulator. Visualize yourself on a dive and using just any other type of scuba regulator. Is the regulator bulky to considerably increase drag and cause jaw fatigue or is it buoyant enough for you to carry around with your mouth? Lightweight scuba regulators use polycarbonate thermoplastics for its housing to make the scuba equipment compact, sturdy and corrosion-resistant that makes them fit for extended use. 4. Nitrox Compatibility. This entails an ocular inspection of the cylinder tank (Nitrogen and Oxygen proportions) and scuba regulator (Nitrox compatibility) specifications. As a matter of convention, most regulators are suited for nitrox mixture use out of the box; containing the standard, maximum proportion of 40% Oxygen (in terms of volume) but then again, there are gas mixes supporting leaner proportions of oxygen such as the trimix. Therefore, check if the scuba regulator supports the gas mixture configured for your diving cylinder prior to purchase. 5. No-Contaminant Feature. As much as possible, choose a diving regulator that has been manufactured using Dry Valve Technology (DVT). DVT operates through an automatic valve that prevents contamination of the first stage mechanism to thus prevent regulator flooding and the entry of moisture or dust particles. This likely improves scuba regulator performance and extends its useful life. 6. Air-Sharing Feature. This feature often associated with octopus regulators (used as a spare demand valve or alternate second stage) will prove to be most helpful during diving emergencies such as a free flow or during diver rescues. High performance octopus regulators such as the Aeris Gyro Octopus Regulator are designed lightweight and with air-sharing feature, while sporting an inline swivel for convenience mounting and flexibility
Dec 01, 2008 | ACCO Brands Apollo Bio-Filter Moisture...
What side does the octopus go on? left or right?
The reason to have it on the right is because that is "standard". I dive with a long hose (7') and an octo around my neck on a 22" hose. So long as you explain it to anybody you dive with and talk about your plan for air sharing in advance, it shouldn't be an issue.
Dec 01, 2008 | Aeris A1 Octo
Scubapro MK25/G250 Hp Regulator Logo
345 people viewed this question
Top Scubapro Scuba Diving & Snorkeling Experts
Bill Boyd
ray gallant
Tom Chichester
Are you a Scubapro Scuba Diving and Snorkeling Expert? Answer questions, earn points and help others
