Question about Samsung SyncMaster 932B LCD Monitor
The screen was unplugged and now when plugged in the blue light around the power buton just flashes
Posted by agezdir on
muhammad faisal saleem muhammad saleem
  • 319 Answers
I tried the reset procedure, i've left it unplugged now for a week and upon ... Now the fifth died. This time, no illumination, just flashing blue light. ... The screen is completely black, the power button is dark blue and no amount of ... The monitor was gone for about 2 weeks (maybe 3) I left it plugged in and ...
deliverator.silverfir.net/?p=369
Posted on Dec 04, 2009
Hp 625
A bit vague? Unplug, remove battery, leave battery out, plug in , push the on/off button. Describe what happens, fan spins? LED's blink? HDD spins up? Sound? Any thing on the screen?
May 26, 2013 | Computers & Internet
My screen kept turning blue for couple of weeks and now i can't get my television off stand by mode
unplugged the tv for a while then re plugged it and power it on, lets see weather it works normal. if doesn't work unplugged it again then remove the rear cover then look for a bulging capacitors in the power supply board.
Sep 27, 2012 | Televison & Video
When computer printer are turned off over night in the mornings all the lights on the control panel are flashing with a blue screen showing B851FE84 the only way it stops is to unplug the power
1. I unplugged the power cord for 20 seconds
2. Hold down the # and 6 keys together and then plugged the power cord back in and hold those keys for at least 10 seconds.
Apr 04, 2011 | Computers & Internet
Pioneer VSX-918V-K Standby Light Flashes but will not turn on.
unplug it and press the power buton and then hold the power button, and while your holding the power button, plug it back in
hope it worked!!!
Jul 30, 2009 | Pioneer Audio Players & Recorders
Moniter went black, power button flashes yellow
it sounds like a capacitor blew from the inverter board.. if u can open it it should be obvious which one the messed up..
May 04, 2009 | HP Pavilion F1903 19" Flat Panel LCD...
My hp 3310 wireless printer freezes and displays a blue screen (on the printer) with alpha numeric characters
Hi
Try resetting the printer
POWER DRAIN:-Turn off the printer, Unplug the power cable from printer and from the wall outlet.Press and hold ON buton for 30-60 seconds.
PARTIAL RESET:-Unplug the printer power cable while its ON, press and hold # and 3 button and connect the Power cord while holding.Wait untill the ON light flashes, then release the buttons.
----(for below reset cartridges must be removed out)---------
SEMI_FULL RESET:-Remove the ink cartridges, Unplug the printer power cable while its ON, press and hold # and 6 button and connect the Power cord while holding.Wait untill the ON light flashes,or wait for 20 seconds,hen release the button.If the printer goes off dont worry release the button and Push the ON button.
FULL NVM RESET:-Take the Ink Cartridges out, Unplug the printer power cable while its ON, press and hold OK and CANCEL button and connect the Power cord while holding the buttons.keep Holding the buttons until the printer goes off ,release the button and Push the ON button.
(Notes - resets will take a while)
Thanks
Riz
Dec 29, 2008 | HP Photosmart 3310 Printer
Lcd sharp tv flashing green light
Try unplugging the unit and while unit is unplugged hold the volume up button and channel down buttons down and while depressing both buttons plug the unit in. Let go of the buttons and the unit should come on in the service mode. There will be a small k on the screen. With the sharp remote press the channel up button once. This should bring up a menu that will show a lamp error line. If the lamp error is = to 5 the unit is in lamp error shut down. User channel down to highlight that line and curser right arrow to highlight the lamp error #. Hit the enter button to clear the lamp errors. Now unplug the unit and let it sit for a minute and plug back in. I hope this corrects the problem. If the unit does not come on by doing this or if it does and you do not find lamp errors the power supply pcb may have been damaged by the surge.
Jan 06, 2008 | Sharp Aquos LC-37G4U 37 in. HD-Ready LCD...
Sceptre X7g Monitor Flashing Red & Blue Lights. Blank Screen
i fixed this problem by unplugging the monitor, unplugging the video cables. Then hold down the power button while plugging it back in. Release power button and then press power button for on. It worked then. I got the icon for no signal, i plugged back in my monitors. Sceptre X9W
Sep 11, 2007 | Sceptre X7GNAGAV 17" LCD Monitor
Samsung SyncMaster 932B LCD Monitor Logo
2,497 people viewed this question
Top Samsung Computers & Internet Experts
Muntejaya Ginting
Muntejaya Ginting
ThaMp3Doctor
ThaMp3Doctor
Tareq Bin Mostaq...
Tareq Bin Mostaq...
Are you a Samsung Computer and Internet Expert? Answer questions, earn points and help others
