Question about Texas Instruments TI-83 Plus Calculator
The graphing function on my ti-83 isn't working. i have reset all the parameters, but i keep getting an "invalid dim" error. ideas?
Posted by kfuller156 on
Anonymous
    New Friend:
  • 124 Answers
Hit 2nd then hit mem then scroll to all and click yes. This will master rester everything and restore it to factory settings.
Posted on Dec 04, 2009
Ti-83 error message invalid dim
You're probably trying to graph a function that does not involve stat
plot features. You can correct this by turning off the stat plot
features. Press "2ND" "STAT PLOT" and then select 4:PlotsOff.
Nov 21, 2013 | Texas Instruments TI-83 Plus Calculator
Invalid dim
You're trying to graph a function that does not involve stat plot features. You can correct this by turning off the stat plot features. Press "2ND" "STAT PLOT" and then select 4:PlotsOff.
Nov 05, 2013 | Texas Instruments TI-83 Plus Calculator
Why do I get an ERR: Invalid Dim 1:Quit Whenever I hit the graph key?
You're probably trying to graph a function that does not involve stat plot features. You can correct this by turning off the stat plot features. Press "2ND" "STAT PLOT" and then select 4:PlotsOff.
If this doesn't do it, could you post the exact function you're trying to graph?
Nov 16, 2010 | Texas Instruments TI-83 Plus Calculator
I keep getting Err: Invalid Dim Dessage on my TI 83 everytime I try to graph
Sep 01, 2010 | Texas Instruments TI-83 Plus Calculator
TI-83 Plus Calculator: My TI-83 reads "INVALID DIM" when I try to graph a...
May 17, 2010 | Texas Instruments TI-83 Plus Calculator
TI-83 Plus Calculator: I am trying to graph an equation and I get the "ER...
If the message appears when you try to graph functions deactivate the statistical plots. To do so:
Press [2nd][Y=] to access (STAT PLOTs)
Select [4:PlotsOff] then [ENTER]
That should solve your problem. Post a comment to this thread if you still have trouble graphing.
If the message appears in another context, it sure would help knowing the context of the error.
May 07, 2010 | Texas Instruments TI-83 Plus Calculator
ERR: INVALID DIM displayed on graphing calculator
The solution for the problem is simple. When you use the calculator to create statistical graphs, it is configured to accommodate the specificities of the problem. However that configuration remains set after you terminate the problem. So when you try to use the calculator to do other problems it uses the stored configuration parameters, which may be incompatible with the new problem. In particular, list of paired-variables must have the same dimensions: There must be the same number of elements in each list.
To make a long story short, you should make it a habit to reset the Ram every time you want to do a new problem. If for reasons of you own you do not want to reset the Ram, you can prevent this type of errors from occurring. This is how you do it.
  1. Press [2nd][Y=] (STATPLOT)
  2. Choose option [4:PlotsOff][ENTER]. Screen displays Done
  3. Press [2nd][0] (CATALOG)
  4. Press [PGRM] (C) to jump to first command that starts with c.
  5. Use arrow to scroll down to ClrAllLists, select it [ENTER]
  6. Calculator displays Done
  7. Start the new problem
To reset the Ram press [2nd][+] (MEM) [7:Reset][1:All Ram][2:Reset]. Press [CLEAR] to erase the Ram Cleared message.
Jan 16, 2010 | Texas Instruments TI-83 Plus Calculator
Graphing Feature error message
This usually happens after the statistical graphs have been used. You should deactivate them. Press [2nd][Y=] (STAT PLOT). Select [4:PlotsOff] [ENTER]. Calculator echoes Done on main screen.
Restart your graphs.
Dec 28, 2009 | Texas Instruments TI-83 Plus Calculator
ERR:INVALID DIM
Apr 20, 2009 | Texas Instruments TI-83 Plus Calculator
Error invalid dim
Apr 11, 2009 | Texas Instruments TI-83 Plus Calculator
Texas Instruments TI-83 Plus Calculator Logo
143 people viewed this question
Top Texas Instruments Office Equipment & Supplies Experts
k24674
Scoee Scoffer
Edward Easley
Edward Easley
Are you a Texas Instruments Office Equipment and Supply Expert? Answer questions, earn points and help others
