SOURCE: TV problem
Are you using cable to get the picture? If you are, make sure the TV set is in the cable mode,If it is then you most likely have a bad tuner in your set. Good Luck
SOURCE: No channels above 47
That works great except I can get the tuner to program any channels above channel47. Is this a limitation of this older model TV yes there is limitation in old tv. is there some setting I can change in order to get more channels using the tv tuner? in INDIA what we do is put a remote control ckt which gives us about 250 channels. of course we replace tuner also called hyper tuner along with remote ckt or replace whole kit which are cheaply available.& serves the purpose. hope this will help
SOURCE: Can I get more channels?
If the tv is capable try to directly enter a channel with a remote you should receive the channel if it is snow or garbled pix ,sound you probably have a bad tuner ( band switching ) If you know anything about electronics you can remove the tuner send it Tip Top tuners. Good luck!
SOURCE: sanyo ds25830
There is a button under the bottom edge of the screen (with the controls) that has the options "Normal" and "CATV" - press this and it should solve your problem.
Tracey
