Question about JVC AV-32120 32" TV
How do I remove the clock display on my JVC tv
How do I remove the clock display on the tv monitor?
Posted by tlshan3 on
"Video One" displays in upper
Press Mode button to select TV. Then press the Display button. Set the Display to Off (choices are Detailed Mode, Clock, Simple Mode and Off). Pressing Menu should turn off the Display at any time.
Support for the LT-37X688 is available from JVC at http://support.jvc.com/consumer/product.jsp?archive=true&pathId=78&modelId=MODL028191 . The direct link to the manual is http://resources.jvc.com/Resources/00/00/92/YA535ien.pdf .
I hope this helps.
Jun 11, 2011 | JVC LT-37X688 37 in. LCD HDTV
JVC AV-31BMS clock stopped
do you mean the time display??
or which clock?
please be clear
Jul 10, 2008 | JVC AV-27D302 27" TV
Time display always on
If I remember correctly on these older CRT JVC sets. It was either press the "display" button on the remote a few times to turn the clock off or the option to leave it on is in the menu system.
Oct 17, 2009 | JVC AV-32260 32" TV
The clock display came on and i can't get it off...
Most clock functions are accessed from MENU ... SETTINGS... TIMER CLOCK ... (Location)... ( Display Y N)
Some options may differ slightly between models But generally along those lines.
I like the clock and wish it would display but mine seems to have a mind of its own It displays somedays and not others, displays on analog and not on Digital on Wednesdays! havent found out why that is either!
Please rate our help to keep the FREE service online++++Thanks for using FIXYA
Sep 14, 2009 | JVC AV-32D303 32" TV
Jvc kds641 changing time display
Here ya go,
1.
Press and hold SEL (select) for more
than 2 seconds.
“CLOCK H,” “CLOCK M,” “SCM LINK,” or
“LEVEL” appears on the display.
2.
Set the hour.
1 Using the << / >> button, select “CLOCK H” (hour) or "CLOCK M"
Use the + / - button to adjust the hour/minute
3.
Press SEL to finish.
4.
To check the current clock time or change the
display mode
Press DISP (display)
repeatedly
During tuner operation it will show the frequency or time.
During CD playback it will show elapsed time or time.
Follow this link to download the manual for your unit in .PDF form.
Mar 30, 2009 | JVC AM FM CD DET FACE CAR STEREO
The digital clock on my 30"JVC is showing in the bottom of screen
The menu screen does not function the display. Without the original remote or a universal remote that does not have a display button, try unplugging the television for at least 2 minutes or more and plug the tv back in. This should reset the tv display. If the universal remote has a display button, depress the display button until you get the desired display results. Reference the user guide below for the display button.
neww.gif JVC AV-36D503 36" TV - User Guide (page #43)
Dec 20, 2008 | JVC AV-36P902 36" TV
On Screen Clock Display
Without the original remote or a universal remote that does not have a display button, try unplugging the television for at least 2 minutes and plug the tv back in. This should reset the tv display. If the universal remote has a display button, depress the display button until you get the desired display results.
Nov 28, 2008 | JVC AV-36D503 36" TV
Can't get rid of clock dispaly
Without the original remote or a universal remote that does not have a display button, try unplugging the television for at least 2 minutes and plug the tv back in. This should reset the tv. If the universal remote has a display button, depress the button until you get the desired display results.
Nov 05, 2008 | JVC AV-36D503 36" TV
Clocked Stopped on bottom of screen
With a Comcast remote, press TV at the top of the remote. Next, press Info and a menu will appear with several options including Clock Stopped. Press Info again one or more times and the Clock Stopped message will be removed from your screen.
Oct 09, 2007 | JVC AV-27230 27" TV
Clock stopped posted at bottom of tv
In order to remove the Clock display on the TV screen press the DISPLAY button on the remote, it may be labeled OSD on older remotes. As this button may bring up more than one display it may be necessary to press it more than once.
Jul 13, 2007 | JVC AV-27230 27" TV
JVC AV-32120 32" TV Logo
601 people viewed this question
Top JVC Televison & Video Experts
Muntejaya Ginting
Muntejaya Ginting
Todd Hill
Todd Hill
Are you a JVC Televison and Video Expert? Answer questions, earn points and help others
