Dont need manuals just pull apart carefully remembering where all the screws go, and use a container so none get lost .... most likely it has got jammed and then confused the logic systemfor ejection sofind the motor with the rubber band that drives the eject and check that it is still on as it is common for it to come off all models and people throw them away! happy tinkering!
Seems that the head is not working, there is no laser scanning and the possibility that the laser head can be defective.
Now certain cleaner disks will not be tracked to run for cleaning as it is not read. Hence it will reject. So it is ideal to clean manually the laser head eye using a cotton bud with gentle pressure on the lens eye.
If there is no result then watch if the CD spins or tries to spin. If so the board seems to work unless a test is taken on the main board but the possibility of a defective optical head can be the suspected fault.
If any of the above seems otherwise we must recheck with possibilities of a malfunction of the main processor board
