No sound. Working yesterday and then today -- nothing.
No sound . I checked all the connections and everything is plugged in . The light on the front of the speaker is green indicating that it is on but there is no sound. These are harman/kardon computer speakers that we got with our original Dell Computer. Never had a problem before and then suddenly -- no sound.
Anonymous
    New Friend:
I cannot believe that you would CHARGE for tech support!!! We fixed the problem by ordering new speakers! OUTRAGEOUS that you make ppl PAY FOR INFORMATION!!!
Posted on Dec 04, 2009
Turn signal flasher
If you had all lights working one day and the next day you had a problem with out doing anything I would first check for a grounding problem. Easy way to fix you problem is to start by reversing everything you did for in prepping for your trailer . Put it all back the way it was and see if all lights work if so and you still want trailer lights then start fresh and connect one at a time . Most trailer wiring color systems are universal meaning they are all the same and depending on the age of the vehicle it is quite easy to install. If you have a newer vehicle (within approx 10 years) you will find that you can buy a "T" connector and it will plug right into a connection at the rear light assembly or a junction connecting left and right side. You can pick up a "T" connector at most automotive stores like Canadian Tire or Lordco . Try this first if you still need assistance i can walk you thru your trouble shoot and re-connection . Good Luck
Apr 07, 2014 | 1997 Dodge Ram 2500 Club Cab
My laptop is completely dead, fine yesterday. Today no lights, sounds nothing. I tried removing the battery , unplugging no response. Thanks,
Remove the battery for at least 3 minutes... Then put it back and then plug in the charger and switch on the charger. If the battery is completely drained, it would take a while for the charging to initiate. Please have patience and leave it on charging even though without the charging indication for at least an hour. After that still if the charging indicator doesn't lit, then its definitely your charger or laptop. You will need to take it to a service centre in that case.
Nov 03, 2011 | Compaq Presario 2170US Notebook
Speakers have stopped working, fully plugged in, was working yesterday and has worked for the past few years. Stopped working today. Nothing wrong with drivers or anything, they should be working normally...
check if the speaker"s light glow when on, second check for ur audio cable connection to ur oc, then check ur speaker attaching it to another computer
if still no result u will have to replace ur speakers
good day
Jun 05, 2010 | Dell A225 2 Speakers
No power
I think your hard drive has had it.
THE SOLUTION: In many cases you can have the data retrieved from your hard drive by using this online company that I highly recommend:
http://www.gillware.com/
Aug 04, 2009 | Computers & Internet
D-Link DI-624 Airplus Extreme G - No power
The power adapter was the problem. Just changed it and everything is back to normal.
Nov 05, 2008 | Computers & Internet
Phillips 27 inch tv
did you check remote like battry, loose nothing is deposited near battry contact etc. if it is getting on from front board and not from remote then fault is due to remote. but if does not start from front also then problem is inside tv. like power supply or horizontal section failure. please do not forget to check plug & socket.
Oct 02, 2007 | Televison & Video
Speakers not working proprerly
This may be in the sound card settings itself. Even though you may have adjusted the Windows settings {if thats what your using} the sound card needs to also be set up for surround. Some sound cards do not support 4 speakers or surround sound systems. Go to Device Manager and find your sound card and manufacture then check there technical support page for info.
Sep 07, 2007 | Audio Players & Recorders
