Menu keeps popping up on screen by it self
This sounds like the front panel assembly(FPA) switches are acting up. What happens with this model is the FPA switches start to conduct just as if someone was pressing the buttons. This in effect locks up the system control or causes it to do erratic things.
The way to determine if the FPA is bad is to remove it by unplugging from set. This requires front panel disasembly. Note:The remote will still work with the FPA removed so the set can be tested.
Also double check that the remote is not the problem by removing it from the room or removing the batteries
Let me know if you need more help or info.
