Question about Samsung PN58B540 58 in. Plasma HDTV
Brand new samsung 58 '' plasma tv will not stay on. Cuts off every 15 to 20 minutes. If dvd player is being used it cuts off and goes to tv mode on its own every 15 minutes.
Posted by carpentor2 on
  • Anonymous Mar 16, 2014
    My tv play for 15 minutes then cuts off
Anonymous
    Scholar:
  • 50 Answers
Hello, my names Dave and I own a plasma / LCD repair shop in Portland, OR. I also sell factory replacement parts for Plasma & LCD type TVs! All the parts we sell are warranted not to be DOA (Dead On Arrival) with a full refund or replacment part! I'm messaging you to let you know that I have all the part for your TV (Samsung PN58B540) in stock! I also provide TV repair tech assistance!
With the brief description you have provided I can tell you that you most likely have a bad A/V board! This board controls input video signaling and power signaling! Please feel free to contact me at www.pleasefixitdave.com you'll find all my contact info at this web site! I would like to get a little more info from you regarding what the TV is doing wrong!
Thank you!
Dave
Posted on Mar 31, 2010
Anonymous
    New Friend:
I love when people say return it, duh
Posted on Jan 09, 2010
Dave Naylor
  • 834 Answers
If it is Brand new I think you should return it ASAP
Posted on Dec 03, 2009
Plasma tv showing "Mode not supported" message
YOU HDMI SWITCHER IS DEFECT OR YOUR TV IS NOT COMPATIBLE
Apr 24, 2010 | Samsung PN58B860 58 in. HDTV Plasma TV
Mode not supported message
ok there should be be a setting in the menu probably called video source depends on what model it is, make sure you put it on hdmi,this should do it, let me know if it helps
Apr 18, 2010 | Samsung PN58B860 58 in. HDTV Plasma TV
DVD picture is pink
check that all leads are pushed in
Nov 29, 2009 | Panasonic TC-P42X1 41.6 in. Plasma HDTV
32 inch tv/dvd combo cuts off on its own
The main power supply regulator section circuit fault. Either it will be a separate board, or the part of main board. Check and replace damaged component/s at its main power regulator [SMPS] section circuit. Contact any service technician. If you wish to get some details; check the site linked here. Pull up older posts.
https://electronicshelponline.blogspot.com/
It will be best to replace the power supply regulator board as card basis rather than making "Surgery" to it; which usually will make loss for both money and time. Even though you can make it right, it will cost around an amount equal to the cost of a new board; including the cost of (spare parts + service charge) More to say, most of the spare parts to it will be difficult to get from open electronic spare part market. This is true to most of the flat panel TV power supply boards; irrespective of its brand and screen size.//
Feb 05, 2018 | Akai LCT3701AD 37 in. LCD Television
UPCONVERT DVD PLAYER HDMI PROBLEM
I have the same issue with this player hooked up to a Samsung 58 inch 1080p plasma.
Jun 06, 2008 | Televison & Video
Sound cuts out every so often when using Coax Digital In
DI cables have little end caps, make sure they are removed
Mar 04, 2017 | Audio Players & Recorders
DVD picture cuts in and out first 15 minutes
This is like the problem I had for some months. After a lot of exchanging cables and troubleshooting on forums like this, I decided to call in the Sony service engineers.
The problem turned out to be nothing more than a menu selection. You need to check the setup menu under video and select the colour system you are using (NTSC, PAL). The factory setting on the TVs is 'auto' apparently and sometimes a weaker signal will cause the auto colour setting to drop in and out. In our case we set it to PAL and the problem has not recurred.
Sep 03, 2007 | Pioneer DV-545 DVD Player
Samsung PN58B540 58 in. Plasma HDTV Logo
288 people viewed this question
Muntejaya Ginting
Muntejaya Ginting
 Grubhead
Grubhead
