SOURCE: screen blanks out
A digitalizing picture is most likly a bad connection on a screen driver cable or the driver itself is intermittant or the power supply has an intermittant filter on the substain B+ line. hope this hellps.
SOURCE: need a remote control for
I have a PME-42S6 on Ebay that has a turning on problem it is a complete unit and work good if you can get it to turn on
Ebay # 120362175465
bid on it and pick it up and there is your remote control
Bob
678-333-6746
SOURCE: We are looking for a
If you are still looking for a base for you sampo I have one. My old tv died and I bought a new one. The stand was never used because I mounted mine to my wall. The model was the 42"
SOURCE: Sampo plasma TV 42inch
a few things to look at , verticle lines.. sustain boards or one of the screens film cables became cut or broke an internal connection in the film. resulting in the need of a new pdp modual (screen) i am also aware that this model uses a media box in the back that fits into two 20 pin or so connectors, remove, make sure all pins are straight and clean them with acetone and a brush. re-plug the media box and see if its ok, if not look at the sustain boards y&z respective of what side of the set its on. Keys on the set, ive had the vol keys get stuck , i notice i had to back the screw out that holds the button panel just a bit to free the keys..its in a small spot on the bottom left, looking from the back (open) give it a turn and a half and try it.
SOURCE: need universal remote control code for maxent 42" plasma tv?
I hope that you have gotten this resolved, but if not, or if you have any other questions, here are the codes and some simple steps to run through.
1. Hold down the clear TV button until all lights light up at the top of the remote
2. Punch in a 3 digit code (provided below)
3. Press the # (POUND) button
4. Try powering the tv on/off, and the volume. If one or more of these functions do not work, start over from step 1 with a different code
246
730
746
Becki Barned
DISH Network Customer Service
