Question about Whirlpool MH7135XE Microwave Oven
My microwave stays on while door is open--my right eye has been giving me problems, I am worried about the waves causing me to have flinching eye--it is the right eye that faces the oven whiled it is open The microwave was bought in 1997--are there any recalls on the oven? model MH7130XEZ-1 Serial-FGG5309780
Posted by sixjsmail on
zappal
    Sergeant:
  • 256 Answers
The fan may be on when the door is open but the oven is not generating microwaves at that time. Replace defective microswitch.
Posted on Dec 05, 2017
1 Related Answer
MicrowaveSvc
William Miller
  • 9179 Answers
SOURCE: Whirlpool Microwave Model MH7130XEZ-2
Generally, the most common causes of a failure to heat are:
- bad door switches or door switch mounts
- loose connection at the magnetron
- problem or loose conneciton on the control unit circuit board
- bad magnetron or other high voltage part
At our site, we have critical safety information, info on door switch diagnosis and replacement, and disassembly information.
See our listing here on FixYa: http://tinyurl.com/yzjozk
Posted on Oct 22, 2007
I have a emmerson 1000 watt microwave its about 3 or so years old. it stays on even when the doors open. so when its done and u take it out, it keeps on going around?
micro-switch if faulty or in stuck position thinking that it is okay to start/run microwave . these machines are mostly made in china and are sensitive of slamming the door too hard the plunger that insets into wave there is a micro-switch, you will have to take apart the wave..sorry ..
Oct 14, 2017 | Microwave Ovens
Model em-p672w. What caused it to stop working?
Sanyo EM-P672W Microwave Oven Repair Questions ...
www.fixya.com > Forum > Microwave Ovens > Sanyo
Recent Sanyo EM-P672W Microwave Oven questions, problems & answers. ... Mysanyo super shower microwave wave stopped working it shows on the display to press clock key but ... What would cause my Sanyo Microwave to not heat up?
Sanyo EM-P672W Microwave Oven Sanyo microwave fuse ...
Nov 19, 2015 | Sanyo Microwave Microwave Oven
When my microwave is cooking something i press stop and open the door but its still cooking..is this SAFE to be exposed to the radiation like that or what could be the problem??
It is definitely not safe to be exposed to microwave radiation like this. It can cause eye cataracts to develop. The unit has a faulty door safety interlock, which should cause it to cease cooking when the door is opened. Don't use it until it is fixed.
May 31, 2015 | Microwave Ovens
I read that after any repairs to a microwave you need to have a microwave waves test done to make sure it is not leaking. Is this right? So even if I repair it myself I still have to take it in for th
As long as there is no damage to the lining or the door, you do not need to worry about leakage, all microwaves leak a small amount so testing with wireless notebook would give false readings
Sep 29, 2014 | Microwave Ovens
My micro wave door opens n does not shut tightly I guess and so takes about ten tries opening n shutting before it starts. What should I do Panasonic inverter microwave (the genius prestige) Model...
The door is either out of adjustment, the door switches are out of adjustment, or the door/hinges are damaged. If the door switch assembly can be adjusted to fix the problem, then make sure the door closes as snugly as possible. As any repair to a door can increase the amount of microwave leakage, which can cause possible health issues for you, it might be wise to, at the very least, have a technician do a radiation leakage test on the unit once the door problem is repaired.
If you need further help, I’m available over the phone at https://www.6ya.com/expert/david_29ad5d1dd86564b0
May 08, 2014 | Microwave Ovens
After closing door micro wave turn table continues to turn and light stays on after you open door and take out food.
The problem is most likely caused by a defective door switch, and should be rectified for safety reasons.
Apr 05, 2011 | Whirlpool WMH1162XVS Microwave Oven
Rust marks on inside trim
IF YOU USE THE MICRO WAVE ALOT WHEN YOU COOK SOMETHING THE STEAM FROM THE FOOD BUILDS ON THE INSIDE AND CAUSES THIS PROBLEM. THE HINGES ARE OPEN AREAS WHERE THIS STEAM CAN COLLECT. NOTHING TO WORRY ABOUT
IT'S JUST ONE OF THOSE THINGS THAT HAPPEN
Sep 15, 2009 | Samsung MW5592W Microwave Oven
Micro wave broke
open the door and look on the middle top right inside the microwave is it burned or blackend?You have a faulty magnatron.if it is.
May 19, 2009 | Magic Chef MCD1311ST Microwave Oven
Whirlpool MH7135XE Microwave Oven Logo
291 people viewed this question
Top Whirlpool Microwave Ovens Experts
William Miller
William Miller
Michael Thomas
Michael Thomas
Are you a Whirlpool Microwave Oven Expert? Answer questions, earn points and help others
