Question about Northgate 17" LCD Tilt Screen Innovations Monitor
How do you fix a 90 degree tilted monitor sreen??
How do you fix a 90 degree tilted monitor??
Thanks
MIke
Posted by mrennick on
Anonymous
  • 42 Answers
Ctrl-Alt-arrow key....try all arrows, one of them will correct it.
Posted on Dec 03, 2009
10 inch lest tilt Unisaw will not tilt to complete verticle --only goes to 88.5.
There is an adjustment under the table top. It usually is a bolt with a lock nut that allows you to adjust the table to a predetermined angle every time. You can adjust the amount that the table will go by unlocking the lock nut and then turning the bolt the correct direction allowing the table to come to a full 90 degrees. Once you have the table a 90 degrees lock the bolt down with the lock nut. This will aloow you to change the tilt of the table to something other than 90 degrees and then come back to the 90 degrees by turning the adjusting wheel until it bottoms out against the locked doen adjusting bolt.
Mar 17, 2011 | Delta 36-979 10" Left-Tilt Contractor's...
Screen Rotation problem
To revert the screen to normal upright position, press these three keys together:
ALT CTRL and UP Arrow key.
(See attached image)
Hope this solves your problem. Thanks for using FixYa.
Jun 12, 2010 | Acer X193W LCD Monitor
When the screen is tilt back more than 90 degrees shuts off
Look closely at the area where the computer "folds";
there's a small sensor that should trigger when you *CLOSE* the lid -- perhaps, something is triggering that sensor (a small pin) when you're exceeding 90 degrees, putting the computer to "sleep".
Apr 05, 2010 | Compaq CQ60-215DX Notebook
The screen on my monitor is tilted 90 degrees to the left. How do I fix it?
hope this will help out. press and hold at CTRL+ALT then press UP arrow. thanks,
Apr 01, 2010 | Computers & Internet
HP Built-in webcam problem
Webcam usually fix only on its hardware program but if we say to fix it physically, i would say, buy a new one..
Jul 20, 2009 | Logitech QuickCam Messenger Web Camera
Tilting Problem with monitor
Screen position adjustment
To optimize the viewing position, you can adjust the monitor tilt by using
both of your hands to hold the edges of the monitor.
The monitor can be adjusted to 15 degrees up or 5 degrees down.
Jun 06, 2009 | Acer 22" X223w LCD Monitor
Display off 90 degrees
check the buttons on the front ..there should be one to change that back
May 02, 2009 | Dell E196FP 19-inch Flat Panel Monitor -...
Is it possible to change the angle of LCD monitor?
Yes. The LCD monitor on the DiMAGE A2 can tilt to 20 degrees downward 90 degrees upward.
Sep 15, 2005 | Konica Minolta DiMAGE A2 Digital Camera
Computers & Internet Logo
260 people viewed this question
Top Northgate Computers & Internet Experts
Ekse
Carlo Barzo
Carlo Barzo
Tom Chichester
Are you a Northgate Computer and Internet Expert? Answer questions, earn points and help others
