Teac DW-552G BGE CD-RW/DVD-ROM (Combo) Burner Logo
Posted on Dec 03, 2009
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Draivar teac dw-552g - Teac DW-552G BGE CD-RW/DVD-ROM (Combo) Burner
joecoolvette
Level 3:
  • Master 5,660 Answers
  • Posted on Dec 03, 2009
joecoolvette
Master
Level 3:
Answers
5660
Questions
0
Helped
2194316
Points
18014
Here is the drivers you requested,
http://www.teac.co.jp/dspd/download/download.html
If the unit is not functioning properly, it may be that the optical eye is dirty. Use a disk cleaner made for this purpose, or a can of compressed air for computers, and shoot air towards the optical eye.
(The eye is located on the bottom of the drive, under the slide out disk tray)
1helpful
Problem is that my DVD combo TEAC-DW-224E-A reads cds but not DVD kindly help
Download VLC (google it) for free, see if that plays the dvd. Most likely your player has an issue, VLC plays ANYTHING (pretty much!) without issue.
If that doesnt work then you'll have a problem with the actual drive.
2helpful
2answers
I have an external teac dv-28e-n usb DVD writer device which does not recognise and burn DVD rewritablce discs.
I think that Teac DV-28e Is a CD/DVD-ROM only, and will not burn discs. Teac DW-28e is a CD RW/ DVD ROM unit, and will thus play and burn CDs, but will only play DVDs. Check your model numbers to confirm, and then consider exchanging units if you need to burn CDs.
I need decoder
decoder usually means software also called a "codec" those are either automatically installed by windows or manually. If what you are getting ie no video (black player window) but do hear sound then this is your problem.
I use the K-lite codec pack and have yet to find something I can't play. There are others as well. You can download any of the packages at
http://www.codecguide.com/download_kl.htm The basic one is all you need but the other bigger versions include a few extras. Install, reboot and you should be fixed.
2answers
Cannot write dvd
buy one DVD cleaner liquid....
1helpful
2answers
TEAC DW 552g DVD/CD rom combo drive, CD works, DVDs dont
I have your solution, but you are NOT gonna like it, so I hope you will rate it FAIRLY, even though its relatively BAD NEWS.
TAKE A LOOK AT THIS:
Teac (DW552G/KIT/USB2) CD-RW/DVD-ROM (Combo) Burner The Teac (DW552G/KIT/USB2) CD-RW/DVD-ROM (Combo) Burner deliver unbeatable CD speeds of 52X write to CD-R, 32X re-write to CD-RW media and 52X read as well as 16X DVD playback speeds and the drive features an advanced buffer underrun prevention technology. This disc-saving feature suspends the recording process until the buffer is refilled. No more bad discs even when you’re multitasking. It also supports EasyWrite (Mount Rainier), a new disc formatting feature that makes it easier and saves time preparing CD-RW discs for recording. Teac W552G (cdw552g/kit/b) CD-RW Burner Newbie The Teac W552G (cdw552g/kit/b) CD-RW Burner operates with: Microsoft Windows XP, Microsoft Windows...
YOUR DRIVE DOES NOT BURN DVDs, only CDS!!!
1helpful
Teac dw-224e-a dvd rom will not read dvd +r -rw data
Here's the newest driver for your burner. Go to Control Panel, then Device Manager, then click on the + symbol next to disk drives, and double click on the TEAC device. Click the Driver tab and press Update Driver, then choose the 'Let me find the driver' option, and navigate to the folder where you unzipped the file to. Double click and Install. Reboot.
http://www.softwaredriverdownload.com/download/driver/DW224E.ZIP
For burning, I would recommend Nero, Alcohol 120% or ImgBurn.
Good luck and Season's Greetings!
Chris (ziraffa)
Cd burner not working properly
Assuming you have tried different makes of cd or dvd disks, it's a classic drive failure problem where the laser can no longer burn, but may still be able to read cd's only. You will have to replace the drive, they are quite inexpensive, about £30.00 or $60 US and very easy to fit.
Top Teac Computers & Internet Experts
k24674
Grand Canyon Tech
Grand Canyon Tech
Are you a Teac Computer and Internet Expert? Answer questions, earn points and help others
