Question about SanDisk Sansa m230 MP3 Player
I am trying to download an audio book to the Sansa but it won't load. It appears in Windows Explorer for the Sansa, but on the Sansa itself, it does not appear or play. The suffix of the file I'm trying to download is .aax
Posted by rwelkner on
Megasom
  • 699 Answers
AAX files can be played by iTunes and are also supported by the Apple iPod.
To the best of my knowledge, the Sansa unit is not Apple Ipod compatible and therefore cannot play it!
You will need to convert the iTunes AAX files to MP3 format ... providing they are not protected!
Posted on Dec 19, 2009
I have down loaded a bea to delete other songs -also I have one auto book I am not able to delete
What is a 'bea?'
One way to delete songs (and maybe books) easily is to it through your computer, while the Sansa is tethered;
1) Download the Sansa Clip manual. Here's a link;
http://www.sandisk.com/media/327475/CLIP+_UM_0809_ENG+090309.pdf
2) Put your Sansa in MSC (Mass Storage Class) mode.
Go to Settings, then USB Mode. Select MSC mode.
3) Tether the Sansa to your computer. It will look like a USB flash drive.
4) Delete or add Music, or Books.
You can use Windows Explorer to look through the directories on the Sansa, and delete files directly, as you would on a USB Flash drive.
Special Note on Audio Books--
Get an extra memory card, 4 to 8 Gb should do, and use this as your destination for audio books. If you have a book that will not delete, you can pull the card and re-format it, while leaving your songs intact on the main memory.
If you cannot delete the book through the computer or by menus on the Sansa, you may have to re-format your main memory. Hope that helps!
I have the My book Essential 3tb WD drive and windows 7 laptop. It used to work perfectly except that there was a problem with spark coming out of the usb which was replaced by WD and I even got a...
There are several free data recovery softwares that can get data off of drives that Windows explorer won't touch. Check out: http://www.runtime.org/data-recovery-software.htm If you don't mind voiding the warranty, you CAN take it out of the enclosure and try connecting it to another computer, but I really think the encryption is going to prevent this.
The only other option would be to send the drive off to a data recovery specialist which is usually extremely effective, but can be very costly (starting around $400).
I have just purchased a sansa clip + and having problems loading audio books from my computer. I trying to down load books from the internet on audio books. When I hook it up yo my computer the sansa...
click start control panel administrive tools computer management disk management right click on your drive select properties click tools you should see click check now click start two boxes automatically fix files and scan for and attempt recovery of bad sectors place then a tick in both boxes then select check now start or you might tick one box then return after its finished the first repair then return and tick the second box you should not do anything while the chkdsk utility is in progress any input may damage this drive
if you are downloading from the internet
once it starts downloading windows will ask whether you want to run or save it
a browse option will open you can save it into a folder in my documents or another device or a usb device
hope this helps
1helpful
Hi. I have a Samsung Sansa MP3 clip-on player. I listen to audio books all the time. I order an audio book online. It comes to me in either a regular CD or an MP3 version (however they manufacture it)....
Normally MP3 players can only play music/audio files in mp3 file format. You need to convert your CDs to mp3 music files onto yourcomputer or download them from the Internet and then copy them to your MP3player.
You can do this using Windows Media player and Rip the CDs - Media Player willcreate a MP3 music file for each music track.
Click on this link for instruction on converting music files to mp3 file format:- http://www.fixya.com/support/r5798418-creating_transferring_mp3_music_files
1helpful
Trying to transfer audio book from itunes or windows media player
Make sure the usb mode is msc Open my computer click sansa open sub folders delete from here or right click on Sansa select format this will delete all....Try and drag and drop the audio book into the folder assigned Here is the link for the manual and update firmware plus the media converter (http://mp3support.sandisk.com/sansa/Installer/1082/SansaUpdaterInstall.exe)
Once you have the audio loaded and it works sync and try with your WMP......Hope this works
1helpful
Audio book not going into audiobook section on sansa clip
There are two ways to delete files on your Sansa player.  You can delete them from the player directly or using a PC.
METHOD 1 - Delete files directly on the device
For View, Fuze, Clip, e200v2, and c200v2 only
1. In playback mode, press the Submenu button.
2. Select Delete
METHOD 2 - Delete files using a PC
For all other Sansa players:
1. Connect your device to the PC.
2. Select Open device to view files using Windows Explorer on initial connection.
3. Locate the folder where your files are stored.
4. Click to select the files you want deleted and delete the files
2answers
Sansa m250 doesn't continue playing from the same spot after power up
This player will only recognize Audible audiobook files
There is not a fix for the pause/resume issue - it is a major problem for just about every mp3 player that claims audiobook compatibility
Here are some help files:
Audible
1) Adding audible books to your MP3 player using Audible Manager (Windows XP)
Windows - http://mp3support.sandisk.com/audible/xp-audible-add-book.wmv
2) Adding books from an online library to your computer using Audible Manager (Windows XP)
Windows - http://mp3support.sandisk.com/audible/xp-audible-add-books-from-online-library.wmv
3) Adding your MP3 player as a mobile device in Audible Manager (Windows XP)
Windows - http://mp3support.sandisk.com/audible/xp-audible-add-mobile-device.wmv
4) Deleting an audible book in your MP3 player using Audible Manager (Windows XP)
Windows - http://mp3support.sandisk.com/audible/xp-audible-delete-book.wmv
5) Deleting a book from your library using Audible Manager (Windows XP)
Windows - http://mp3support.sandisk.com/audible/xp-audible-delete-book-library.wmv
6) Purchasing an audible book from Audible.com (Windows XP)
Windows - http://mp3support.sandisk.com/audible/xp-audible-purchase-book.wmv
Is the e250 Rhapsody compatible with BMW audio??
You might want to try a casette adapter, if your BMW comes equipped with a casette player - multi-adapters (generic) can generally be found for $10-15. BMW audio books appear to be in Mp3 format, so they should work with the Sansa player.
6helpful
3answers
Sansa Clip Audiobook Question
Once I downloaded the newest firmware the audiobooks folder started showing up in the windows file explorer. So now I don't have to worry about using media player or anything else. I just plug in my sansa clip, open windows file explorer and drag the folders (1 for each disk) onto my player (into the audiobooks folder).
Here's the link for the download. If it doesn't come up you might want to reformat your sansa clip.
http://www.sansa.com/support/sansa_clip/faqs
SanDisk Sansa m230 MP3 Player Logo
Top SanDisk Audio Players & Recorders Experts
Jean Sintulaire
Ekse
Daniel Dollive
Daniel Dollive
Are you a SanDisk Audio Player and Recorder Expert? Answer questions, earn points and help others
