Kodak EasyShare Z612 Digital Camera Logo
Question about Kodak EasyShare Z612 Digital Camera
The pictures have horizontal lines through them. The veiw screen is fine. When you review or save them to the computer they show up whiter and with lines. Thanks ahead for any help.
Posted by mbtodd on
Pania Lee
    Genius:
  • Kodak Master
  • 1,099 Answers
If this doesn't apear on the print pictures taken directly from the SD card. It has something to do with the settings for the picture transferre on your computer.
Try and reset/adjust the settings within the transferre programe. I cannot tell you the eact steps for that since it will depend on the programe you're using. But it can usually be done right before transferring pics to the computer.
If helpful pls. recommend/rate me and or give me a review. TXS
Posted on Dec 03, 2009
1helpful
My Kodak EasyShare Z612 camera has horizontal or vertical lines thru a picture that can be seen in picture review.
The screen needs replaced.You can them Ebay, and they
are not that difficult to do yourself. Good Luck
Horizontal line with different color exposure above and below line on Canon Rebel t3i
Does this occur only on the camera, or is it visible on your PC during PP operations ?
Mar 25, 2017 • Cameras
Horizontal lines on the screen after the picture is taken
Remove the Battery from the Camera then press and hold the power button for 30 seconds. Then, reinsert the Battery pack and turn on the Camera and reset it to the original factory settings by selecting the "Initialize" option under Setup1.
If the issue persists then service will be required.
6helpful
Picture reduced to 1/4 on a black screen
Picture is reduced to a straight horizontal line across the center of the screen.
Lcd black while in picture taking mode
Your ccd appears to be bad. Canon USA will repair this for free. Go here for details. They will send you 2 emails. One with the UPS label and another with info sheets to be sent with the defective camera
http://www.usa.canon.com/consumer/controller?act=PgComSmModDisplayAct&fcategoryid=225&modelid=13390&keycode=2112&id=29819
Taking photos
I have the same problem too with my a430, when i shoot outdoor, it's like over exposed, more of a white, but it's good indoor shooting aside for some horizontal lines. i already reset all the settings, still nothing changed
Will not take picture
the photo sensing device should be displaced from its actual position.......we cannot make it sit in proper position...better take it to a service centre
1helpful
Horizontal LINES
If you are getting fine horizontal lines thet means the picture is over exposing. most probably the apparture or the shutter blade mechanism is not working fine. needs repairs.
Flashing LInes across my screen...
have it looked at immediately before more chaos happens
Top Kodak Cameras Experts
David Shaub
Marvin
Marvin
Are you a Kodak Camera Expert? Answer questions, earn points and help others
