Question about Ariston Technologies Washing Machines
I own IFB toploaded washing machine. It gives E2 error while spinning & sometimes E3. Pls tell can we rectify the problem ?
Posted by shriniwasjc on
Steve Butterworth
  • 938 Answers
Search "ifb error codes" alternatively substitute ariston for ifb.
Posted on Jul 19, 2015
5 Related Answers
Anonymous
SOURCE: E2 error on homemaker washing machine.
I have an E2 error on the display of a homemaker washing machine model no HMWM8000. It will not pump out. The PCB does not have any visibly damaged components, which part is faulty, and how do i test a water level sensor.
Posted on Nov 08, 2009
Anonymous
  • 3 Answers
SOURCE: Heller awm600 washing machine e2 error on spin
A far better and safer way would be to replace the lid.
by wedging a stick in you are bypassing a safety feature and a child or person could sustain a serious injury by openg the lid placing their hand into the drum whilst on a fast spin
Posted on Mar 09, 2010
Anonymous
  • 43 Answers
SOURCE: Haier washing machine E2 error
normally pump filter is the best place to start it could be jamed with a coin or hair clip if you take machine outside and empty it then lay it on its side you can access the pump take it off then stand up the machine and pour hot water into the soap draw check water should run out of bottom freely taking any fluff or bits with it now take apart the pump and clean it all out dry all components before reasembly if the machine still doesent wory could need a new pump
Posted on Nov 11, 2008
Anonymous
SOURCE: IFB Bosch washing machine.
I have an IFB washing maching it does not spin dry the clothes any solution
Posted on Jul 25, 2009
Cameron Scott
  • 105 Answers
SOURCE: LG Washing Machine stops spinning in mid cycle
IE:
• Water supply is not adequate in
area.
• Water supply taps are not
completely open.
• Water inlet hose is bent.
• The filter of the inlet hose clogged.
Solution:
Check another tap in the house.
Fully open tap.
Straighten hose.
Check the filter of the inlet hose.
UE:
• Load is too small.
• Load is out of balance.
• The appliance has an imbalance
detection and correction system. If
individual heavy articles are loaded
(bath mat, bath robe, etc.) and the
imbalance is too great, after several
attempts to restart the spin cycle the
machine will stop and the error code
will be displayed.
Solution:
Add 1 or 2 similar items to help
balance the load.
Rearrange load to allow proper
spinning.
UE:
Posted on Aug 02, 2009
My ifb front load washing machine is showing door error, how can i rectify it
the door is not closing properly so not making the door switch contact to tell the controller to go to the next cycle replace the door lock problem solved eric
Dec 22, 2017 | IFB Washing Machines
In ifb top load washing mechine it gives e2 error code
Google the Make and error codes or search for a video on YouTube
Jan 09, 2017 | IFB Washing Machines
Sir E4 code open help me ifb aw60-8061
There is no matter with this error code. Just switch OFF the device and switch it ON only after 48 hours. It will reset itself. If the error code is E2, there is no need to make it right. It has gone. Buy an other one.
Aug 29, 2016 | IFB Washing Machines
I have IFB washing machine it shows E7 error
Our experienced and skilled technicians are excellent to repair the IFB Washing machine, not only IFB; they will repair all reasonable brands of Washing machines. Our IFB Washing machine Service Center can offer the services within the Hyderabad and Secunderabad zones. We can provide Doorstep service with reasonable cost. call us at 9133356801 & 9133356802. http://aktechnoservice.com/ifb-washing-machine-service-center-in-hyderabad
ifb washing machine service center hyderabad-hgqlgbgiqjunocffergste0f-5-0.jpg
Aug 05, 2016 | IFB Washing Machines
My ifb washing machine top load is got error in timing display as number 4
If the error comes up as E:04, then that is an error code that the washing machine is overloaded.
Try this:
Remove the clothes from the washing machine.
Unplug the machine from the power receptacle for 1 hour.
After 1 hour, plug machine back in and run the machine without the clothes in it until it completes the cycle.
On the next load, do not load the machine with as many clothes.
Please reply to me if this works.
Thank you!
Jun 13, 2016 | IFB Washing Machines
Topload washing machine e5 eror solution we need
search Google for that make and error code . perhaps you will find it
Jun 28, 2015 | IFB Washing Machines
Error code (E2-E3)in toshiba washing machine AW1190S
Try replacing lid close sensor...mine one has E2 due to broken wire...
Feb 03, 2013 | Washing Machines
Ac voltage become hihg or low when start ifb washing machine
Dear, Sir in my IFB Washing...i got a Ac Lo error hiw i fix this Error washing stopped plez give reply sir
Sep 30, 2012 | IFB Washing Machines
Washing Machines Logo
2,719 people viewed this question
Top Ariston Technologies Washing Machines Experts
Marvin
Marvin
Harrie
ray gallant
Are you an Ariston Technologies Washing Machine Expert? Answer questions, earn points and help others
