Question about JVC GY-X3 Camcorder
I need batteries for a JVC GY X3 camera, do you know the model numbers of these batteries? It takes two different sizes.
Posted by kurtlawn on
Anonymous
    New Friend:
I also look for the battery but i didnt find them yet .please if you will find something contact me in [email protected]
Posted on Dec 11, 2010
1 Related Answer
Anonymous
  • 10 Answers
SOURCE: I need batteries for a JVC GY X3 camera
It’s NP-1 and NB-G1 batteries.
Posted on Mar 23, 2010
JVC GY-HD100 is unable to capture to final cut pro. It shows "no communication" in the log and capture window. But It will capture useing IMovie with no problem. This creates an extra step in my...
You should select the Easy Setup preset that matches the cameras output before capturing.
You may need to start a new project for the Easy Setup to take effect.
Mar 03, 2011 | JVC GY-HD100 Mini DV Digital Camcorder
I have a jvc GY-HM100U High Definition Camcorder and when I use a pny 4GB sdhc card and put the Video on my Mac I can't play the video because I either get an error message or it says it can't read the...
The gy-hm100 can record to sdhc media up to 32gb in each slot (total 64gb). For best performance you must use class 10 sd cards. Your camera may need updated firmware that enables class 10 support so check the JVC Pro website and follow the firmware instructions if you haven't done so already. Also, make sure your card is formatted and unlocked with plenty free space. 4 gb is not much at all and a card that size may not be of sufficient speed to operate correctly in the gy-hm100.
Jun 10, 2010 | JVC GY-HM100U High Definition Camcorder
Where can I find batteries for this camera JVC GY-X2B
Hi...
If you want to find a battery of your camera you can find that in ebay website. This is an online selling website. Got to www.ebay.com find your camera battery.
ICmanServer
Aug 11, 2009 | JVC GY-X2B S-VHS Analog Camcorder
JVC GY-HD110U
discharge your batt. fully. charge your batt. on 3phase current. dont remove in middle, give time for your batt. to charge fully
ues JVC original batt.
Jun 18, 2009 | JVC GY-HD110U Camcorder
JVC GY-HD110U won't turn on with battery power only AC power.
There is an issue with the a small yellow part of the AC plug breaking off in the camera. The camera thinks it's still plugged in, so it won't run on the battery. If you can get a small tool to fit into the inlet you can break the piece up and pull the parts out. I haven't had any luck with it, but read others doing it.
Apr 24, 2009 | JVC GY-HD110U Camcorder
The fuse on my JVC GY HD100 is dead. Can I replase it with somone other? Why dos it say: "Replace with same type of fuse" on the board? What is a cemical fuse
It is a very small fuse (about the size of a grain of rice) that is directly soldered to your circuit board. It is not a user replaceable part. You'll have to send it back to JVC to replace. In the future, what you need to do is power off when changing the battery.
Dec 26, 2008 | JVC GY-HD100 Mini DV Digital Camcorder
JVC GY-X3 Camcorder Logo
198 people viewed this question
Top JVC Video Cameras Experts
Muntejaya Ginting
Muntejaya Ginting
Ekse
Larry Stiles
Larry Stiles
Are you a JVC Video Camera Expert? Answer questions, earn points and help others
