Remove Mains Plug and press Standby switch from LED Panel for 30 sec.
Press Input & Ch Down Switch from LED panel and plug in and start LED
LED will start and "K" will appear on screen
Press Ch Down & Vol Down switch at same time
You will get 1/10 page on screen
Go to 9/10 page by pressing left & right button from remote
Select EEP and press Ok button from remote
After 30Sec remove main plug and restart LED.
These blinks [flashes] are fault indication (Error Codes). From the number of blinks occur at one time switch ON, you can get an idea about the faulty circuit section inside it. This will make repair easy. These are called blinking codes. Make sure about the exact number of blinking of the standby/power LED, by switching On & OFF the set, for at least two times. Count it carefully. If you wish to get some details, check the site linked here. It has details about blinking codes, and fault locating procedure, to many popular brand TVs and other devices. http://electronicshelponline.blogspot.com/
Blinking codes details of many popular brand TVs are given. Surf the site with patience. If blinks continue without any pause, the main board [One see at the left side; Green coloured] is faulty.
Turn the Navman off by holding the power button in the upper left corner of the device until the screen goes blank.
Plug the unit into its charger using the USB port on the
bottom of the unit. The battery indicator light next to the power switch
should turn orange, indicating that the device is charging. Once the
light has turned green the charge is complete. If the light does not
turn on, verify that the car charger is plugged into a working outlet.
Those blinks [flashes] are fault indication (Error Codes). From the number of blinks occur at one time switch ON, you can get an idea about the faulty circuit section inside it. This will make repair easy. These are called blinking codes. Make sure about the exact number of blinking of the standby/power LED, by switching On & OFF the set, for at least two times. Count it carefully. If you wish to get some details, check the site linked here. It has details about blinking codes, and fault locating procedure, to many popular brand TVs and other devices. http://electro-medical.blogspot.com/ http://homenol.blogspot.com/ http://electronicshelponline.blogspot.com/
If blinks continue without any pause, the main board is faulty.
Search the site by type in the "brand name" to your device, in the "Search box at the top right of the display window of the Homepage" to get gathered related posts.
i had same problem today, it had locked up during deal/no deal unplugged it three times nothing happened, wouldn't switch on unplugged again left it for 5 minutes then plugged in and left alone for 15mins plus lights flasing then evetually green light went all ok
Here is a wiring diagram of the radio by wire color:
Radio Constant 12V+ Wire: Green/Yellow Radio Switched 12V+ Wire: Yellow/Black Radio Ground Wire: Black/Green Radio Illumination Wire: Light Blue/Red Radio Dimmer Wire: n/a Radio Antenna Trigger Wire: Blue Radio Amp Trigger Wire: Blue (Same as Antenna Trigger) Front Speakers Size and Location: 5′ x 7′ Doors Left Front Speaker Wire (+): Orange/Light Green Left Front Speaker Wire (-): Light Blue/White Right Front Speaker Wire (+): White/Light Green Right Front Speaker Wire (-): Dark Green/Orange Rear Speakers SIze and Location: 5′ x 7′ Rear Deck Left Rear Speaker Wire (+): Gray/Light Blue Left Rear Speaker Wire (-): Tan/Yellow Right Rear Speaker Wire (+): Orange/Red Right Rear Speaker Wire (-): Brown/Pink
