Sony Grand WEGA KDF-60XS955 60" Rear Projection HDTV Logo
Posted on Dec 03, 2009
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Image and sound comes on then goes away and the lamp stand by light starts blinking. I have fix it some times by putting a fan on the back of the tv but it is not working now it is a sony wega projection tv
Anonymous
Level 3:
  • Master 556 Answers
  • Posted on Dec 04, 2009
Anonymous
Master
Level 3:
Answers
556
Questions
0
Helped
154234
Points
1096
Sounds like your lamp has gone out change it.
1helpful
I have a Samsung HL-P5067W/HL DLP tv. When I turn it on cold the lamp light blinks on and off. The fan makes a high pitch sound a relay clicks the TV goes back to standby and the lamp light starts blinking...
This sounds like a lazy lamp--that is getting hard to start. Try a new lamp first. If you are inclined to do so--get a bard bulb and install in the old lamp housing and save some money. Get a real PHILLIPS bulb--it will last a while--compared to cheap generics that are good for maybe 6 months !!
1helpful
Power light is flashing 3 times consecutively. When hitting the power button the fan comes on then shuts back down..then starts flashing the red light again..I've recently bought a new lamp and installed...
Put lamp cover back in its place as 3 times blinking light shows lamp cover has not been fixed.
Lamp cover is first thing that you removed to replace lamp in tv, make sure it is fixed securely in its position.
TV DOES NOT COME ON
the light bulb is most likely burning out or lamp hours have set a certain hours and lamp will need to be replaced or lamp hours need to be reset.
After a power failure I have 4 red blinks and tv
The fan has stopped most likey a problem with the AGU board
1helpful
I have a similar problem with the Sony 60" wega SXRD rear projection TV. The green light blinks on the power/display LED and the picture comes on for a few seconds and then the screen goes black . Then the...
I believe 4 blinks is fan error. You can take back off and watch fans in particular the fan for the lamp (this one goes out the most) The TV has a sensor so it knows if the fan turns.You can take a pencil and use it to spin fan sometimes that will jump start it (not a permanent fix just a test). You can try cleaning dust off fan and replugging the connector on the wires coming from fan.Might fix it if not fan will need replacement.
3helpful
4answers
Problem with Sony Wega 50 in kdf-50we655 light blinks 55 times
Symptom shows that TV needs Lamp replacement.
Sony TV Lamp is available in Part Store and lamp replacement procedure is written in user manual of TV.
2answers
Samsung 46" DLP
HLP, HCN HL-S The Start-up Problem or/and
3 LEDs in the front blinking.
Unplug the set, pull out the lamp module (not all the way - leave it on the track) and push it back in.
Power issues (Tv not turning on) were typically due to faulty ballast. While the TV reports a bad lamp it is the ballast itself causing the issue. Samsung is well aware and will replace both the ballast and the lamp (since the lamp can be prematurely aged but the bad ballast). After replacment most people stop having issues.
Top Sony Televison & Video Experts
Grand Canyon Tech
Grand Canyon Tech
ZJ Limited
ZJ Limited
matt martin
matt martin
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
