Question about Motorola Mobility W385 Cellular Phone
How do I record new outgoing voicemail message
Posted by sage_travel on
biggdaddyd
    New Friend:
  • 15 Answers
Depends on your provider, if you call your own phone number (voicemail) it should give you options to change a few things, if not contact ur provider
Posted on Dec 03, 2009
How do I fix the voicemail from keep calling back
Delete the mailbox, and re-install it. Then re-record all your outgoing messages.
Oct 20, 2015 | Samsung Falcon iDCS 18D Display Phone with...
Record an outgoing voicemail greeting
It's not in the manual for the good reason that the AT&T 992 isn't an answering machine. If you want to record an outgoing voicemail greeting, you'll have to do it on the voicemail system, not on the phone.
Nov 25, 2013 | AT&T ATT-992 Corded Phone
Record outgoing voicemail greeting
The AT&T 992 isn't an answering machine. If you want to know how to record an outgoing voicemail greeting, you'll have to tell us the make and model of the voicemail system.
I have recorded an outgoing message. However, at the end of the new outgoing message an old obsolete outgoing message starts to play. How do I get rid of the old outgoing message?
You will need to remove the old message. There SHOULD be prompts. IF NOT try going to a very quiet room and hit record but do not say or make noise and this will record silence over the old and new message. Then attempt to retry.
ALSO - look for a 'reset' button and remove all batteries if you have power outage back up batteries.
Unplug the phone - and try again.
Here are the instructions from the manual:
To Change Your Personal Greeting:
1. Press the Check Voicemail key or press the Feature button, then 981
2. Enter your password
3. Press the ADMIN softkey
4. Press the GREET softkey
5. Press the REC softkey
6. Press the PRIME softkey
7. Press the YES softkey
8. At the tone, record your new greeting, press the OK softkey to end your recording and then the OK softkey again to accept the new recording
Best of it
Gary @ Fix Ya
Jul 20, 2011 | NorStar M7324 Telephone
I am trying to record my personal greeting on my message machine with the DECT 6.0...can you please explain to me how I can record my greetings?
Which model phone do you have? For the CL82509 and related DECT 6.0, you need to set the outgoing message from the handset when the answering machine is on. (It can be turned on from the handset).
For the outgoing message: with the handset in Idle mode, press Menu/Select. Use the up (Dir) and down (CID) arrows to highlight Ans Sys Setup. Then press Menu/Select. Use the same arrow keys to select Announcement and press Menu/Select again. Press 7 to record a new announcement. At the tone, speak your message clearly then press 5 when you have ended the message. The message will play back.
This model's manual is available here: http://att.vtp-media.com/ecp/documents/product_Product/132/UserManual/5995/cl82509_manual_USA_i6.pdf . See page 15 to set the answering system outgoing message. (This is different than Voicemail. To set up Voicemail, you will need to see your telephone provider's documentation.)
Most AT&T phone manuals are available here: http://telephones.att.com/att/index.cfm/product-support/manuals/ .
I hope this helps.
Apr 01, 2011 | AT&T DECT 6.0 Cordless Phone System with...
1) voice mail light blinks but don't know how to retrieve messages (we are renters and don't own phone) 2) Our outgoing works ok but we aren't getting messages.
You apparently have unheard messages on the voicemail system provided by your telephone company. This system records messages when someone calls while you're already on the phone. Please contact your telephone company for instructions on accessing their voicemail system.
Mar 04, 2011 | Vtech DECT 6.0 Cordless Phone with Digital...
How do you change the outgoing message on this phone?
Need to acces the mailbox for that phone as the mailbox owner, then enter the options menu and listen to the prompts to record the outgoing message.
Dec 08, 2010 | Lucent PARTNER18 Corded Phone
Creating an Outgoing message that tells a caller to leave a messa
To Create Your Personal Greeting:
Please let us know if that was helpful enough.
Good Luck & Thanks
Shiv.
Aug 13, 2009 | NorStar Flash Voicemail Power Supply Only...
Record outgoing message
Call your service provider and ask them what their voicemail service number is an dset up your voicemail that way.
Mar 11, 2009 | Samsung SGH-G800 Cellular Phone
I can't remember how to record my outgoing message ?
here you go...
Recording your greeting
message
You can record your own greeting
message (max. 2 minutes and 30
seconds). If you do not record a
greeting message, a prerecorded
greeting message is used.
1 {MENU}
2 {V}/{^}: “Answering devicei
{OK}
3 {V}/{^}: “Record greetingi
{OK}
4 After the handset beeps, speak
clearly about 20 cm (8 inches) away
from the microphone.
5 To stop recording, press {OK}.
6 {OFF}
If this helps you solve it, plz rate this fixya. Thank you kindly.
Feb 01, 2009 | Panasonic (KX-TG1032S) Phone
Motorola Mobility W385 Cellular Phone Logo
217 people viewed this question
Top Motorola Mobility Cell Phones Experts
Thejus Mt
Thejus Mt
Level 1 Expert
Lawrence Oravetz
Vernon Taylor
Are you a Motorola Mobility Cell Phone Expert? Answer questions, earn points and help others
