What are the connections for the hp media center m7060n power supply? i pulled the old one out to check that the fuse blew and ended up ordering a new one but i was a ******** and didn't mark where each connection goes.
It could mean some internal component is damaged, and your desktop is simply unable to be powered on. However, make sure to check your power cable is plugged in, and power is actually switched on (check the back of your machine).
If there's no evidence of power at all (no lights, etc.) you have likely lost the power supply. These are simple to replace and can be found at a number of sources, including eBay, for around $30.
On HP computers, I believe that this means that the power supply or the motherboard is bad. I assume that the outage was due to the thunderstorm and you may have received a surge. In your manual, there should be diagnostic light codes where they will outline the exact meaning. Again, to the best of my knowledge, this means that there is a bad power supply or a motherboard.
hi friends, unpluug the power chord from the wall jack after that press and hold the power button in the front for about 15 seconds, connect the chord back in and try it. if it does the same then look at the rear side of the cpu box (where the power chord goes in and look for a small fan inside the power supply box, it has to be spinning). if not then the power supply (smps) has goen bad. now if the fan is sipnning try disconnecting all the extra periferals eg printer and stuff, still nogo then try opening the cpu box (reffer owners manual). take the RAM out and try to power up the system, if it starts beeping like beep ...beep... peeeep... then turn it off put the ram sticks back in and it should work fine...
NB:-for the owners manual check this out: http://h10025.www1.hp.com/ewfrf/wc/manualCategory?cc=us&dlc=en&product=470506&lc=en&jumpid=reg_R1002_USEN
OK FIRST A POWER SURGE PROTECTOR WILL ONLY PROTECT YOU 7 % OF THE TIME, WHICH YOU JUST REALIZED. SO YOU NEED TO BUY A BATTERY BACKUP ALSO KNOWN AS A UPS.... I CANNOT STRESS THIS ENOUGH. BRING YOUR PC TO BEST BUY AND THEY WILL TEST YOUR POWER SUPPLY, IF IT TESTS OUT OK THEN YOU BLEW SOMETHING IN YOUR MOTHERBOARD. GET A BATTERY BACKUPS/UPS!!!!!!!!!!!!!!!
