Question about Ariston Technologies Ovens
SOURCE: Jenn Air 88370
You need a new knob part y715403 . Turn knob clockwise first clik should be bake position
Posted on Jan 09, 2008
SOURCE: Smeg Oven
Hi ! have a look at link below
http://www.smegtech.com/site/smeg/pdf_libretti/914772191-GB.pdf
Posted on Apr 10, 2008
SOURCE: Need replacement Dial knobs on Oven
Look in yellew pages for a Zanussi dealer, you will need mod number,,serial number, and er number, all of which are on the rating plate found at the front of the oven.
Posted on Nov 17, 2008
SOURCE: I have an AEG cooker but the marking around the cooker knobs have
Hi.
You need thermostat knob and main oven control knob.
Posted on Nov 20, 2008
SOURCE: can no longer read the temperatures around the oven knob
On the 720EF the numbers are recessed behind a small glass panel, so I think you are not talking about the same unit. If all else fails, I suggest you buy an oven thermometer from say Lakeland - they are about 4 to 5 pounds and are good. Run the oven, making a note where the marker is and see what temperature the thermometer gives.
Failing that, run the oven with the thermometer in all the time and experiment to see what the control; knob is pointing at for any given temperature.
Posted on May 08, 2010
Testimonial: "Thanks for that, will try it asap!!"
Oct 20, 2017 | Tecnik Ovens
May 29, 2011 | Tecnik TKC8525 Double Oven
Apr 10, 2010 | Stoves 720EF Electric Double Oven
Jan 23, 2010 | Ovens
Nov 29, 2008 | Magic Chef 9522 Electric Double Oven
Nov 17, 2008 | AEG B1180-4 Electric Single Oven
Mar 22, 2008 | Smeg SE399X/5 Stainless Steel Electric...
Feb 13, 2008 | Ovens
Jan 28, 2008 | Smeg SE399X/5 Stainless Steel Electric...
Jan 08, 2008 | Ovens
23 people viewed this question
