Question about Microsoft Windows XP Home Edition
Windows will not start; the computer continues to boot up to the safe mode selection page. None of the options to start in safe mode have been successful. I downloaded the system and do not have it on disk! How can I get Windows operating?
Posted by stevepatt256 on
  • stevepatt256 Dec 03, 2009
    I can get into BIOS, but cannot restore settings. There isn't an option for that; I can change boot settings, etc., but cannot change OS. I downloaded Windows xp home edition from Microsoft on line, but it may have become corrupt. It was working fine until recently but slowed down. I was not present at the time this problem surfaced, so I don't know exactly what was done, other than the mouse was removed and re-installed.
Anonymous
    Problem Solver:
  • 22 Answers
Ughh, I always hated that safe mode. BUT, you should be able to use your login from there. You stated that none of the options work. Same has happened to me. Somehow your operating system became corrupt it sounds.Can you even boot into the very first OS that existed? Get into the BIOS? From there you should be able to "restore settings/config" Try that. What do you mean you downloaded the system? Is it a cracked copy? O-o That could be the problem as it has already detected that it is cracked, as in not a legit copy. Some keygens do not even work. You may have to do a fresh install, and in the meantime, think about buying a legit copy. Because of legalities here Im sure, I cant go into that much further :-P
Posted on Dec 03, 2009
Start my pc on safemode
Windows 2000 and XP users Tip: If you are running Safe Mode because you cannot get into Windows, you may want to first try loading the last known good configuration.
To get into the Windows 2000 and XP Safe mode, as the computer is booting press and hold your "F8 Key" which should bring up the "Windows Advanced Options Menu" as shown below. Use your arrow keys to move to "Safe Mode" and press your Enter key.
Note: With some computers, if you press and hold a key as the computer is booting you will get a stuck key message. If this occurs, instead of pressing and holding the "F8 key", tap the "F8 key" continuously until you get the startup menu.
Trouble Getting into Windows 2000 or Windows XP Safe mode - If after several attempts you are unable to get into Windows 2000 or Windows XP Safe Mode as the computer is booting into Windows, turn off your computer. When the computer is turned on the next time Windows should notice that the computer did not successfully boot and give you the Safe Mode screen.
Please select an option:
Safe Mode
Safe Mode with Networking
Safe Mode with Command Prompt
Enable Boot Logging
Enable VGA mode
Last Known Good Configuration (your most recent settings that worked)
Directory Services Restore Mode (Windows domain controllers only)
Debugging Mode
Start Windows Normally
Reboot
Return to OS Choices Menu
Use the up and down arrow keys to move the highlight to your choice. Once you're done in Safe mode if you want to get back into Normal Windows restart the computer like you normally would and let it boot normally. Click here to get additional information about getting out of Safe mode.
loading the last known good configuration.To get into the Windows Vista and Windows 7 Safe Mode, as the computer is booting press and hold your "F8 Key" which should bring up the "Windows Advanced Options Menu" as shown below. Use your arrow keys to move to "Safe Mode" and press your Enter key.
Note: With some computers if you press and hold a key as the computer is booting you will get a stuck key message. If this occurs, instead of pressing and holding the "F8 key", tap the "F8 key" continuously until you get the startup menu.
Trouble Getting into Safe mode - If after several attempts you are unable to get into Safe Mode as the computer is booting into Windows, turn off your computer. When the computer is turned on the next time Windows should notice that the computer did not successfully boot and give you the Safe Mode screen.
Choose Advanced Options for: Microsoft Windows Vista
Safe Mode
Enable Boot Logging
Enable low-resolution video (640x480)
Last Known Good Configuration (advanced)
Debugging Mode
Disable automatic restart on system failure
Disable Driver Signature Enforcement
Description: Start Windows with only the core drivers and services. Use
when you cannot boot after installing a new device or driver. Once you're done in Safe mode if you want to get back into Normal Windows restart the computer like you normally would and let it boot normally.
Aug 13, 2014 | Computers & Internet
Wont boot in safe mode
start your laptop before booting windows press f8 button continuously
ndows 2000 / XP users
bulb.gif If you are running Safe Mode because you cannot get into Windows, you may want to first try loading the last known good configuration.
To get into the Windows 2000 / XP Safe mode, as the computer is booting press and hold your "F8 Key" which should bring up the "Windows Advanced Options Menu" as shown below. Use your arrow keys to move to "Safe Mode" and press your Enter key.
Safe Mode
Enable Boot Logging
Enable VGA mode
Debugging Mode
Reboot
Microsoft Windows Vista and Windows 7 users
Sep 27, 2011 | Lenovo G460 Laptop Computer - 06779XU...
How do you put windows into safe mode?
Power on or Restart your computer, keep tapping F8 on the keyboard while it boots up. After few seconds, you'll be taken to the "Advanced Boot Options" with "Safe Mode" in the lists. Use the Up-Down arrow keys to highlight the "Safe Mode" and press enter on the keyboard to confirm the selected boot options. Black Screen with white texts will be displayed on the display, wait for few seconds until you see the windows logon Screen. You'll also see a confirmation message box asking you to confirm to boot into Safe Mode, click "yes" or "Ok" and proceed forward. There now you are in the Safe Mode.
If you need further help, let me know.
Good luck.
Thanks for using FixYa.
Sep 26, 2010 | Computers & Internet
How do I put my HP computer in safe mode.
Just after post(the computer boots up) and just before you see windows booting press F8, it will bring up a blck page with different selection options to boot your pc, use the arrow keys to go to the top of the page where it says safe mode and hit enter,, the computer should now boot to windows in save mode. hope this helps.
Sep 23, 2010 | Computers & Internet
XP wont load in safe mode
MAY BE DUE TO LOT OF VIRUSES. DISMOUNT YOUR HARDDISK FROM YOUR SYSTEM AND SCAN IT FOR VIRUSES IN ANOTHER SYSTEM WHICH HAS THE LATEST UPDATE OF A POWERFULL ANTIVIRUS SUCH AS KASPERSKY....
Sep 23, 2009 | Microsoft Windows XP Professional With...
Continuous windows xp startup failure
That's usually caused by a bad system driver. Next time it boots to the "start windows normally" page, select 'safe mode'. If the system boots well in safe mode, you can start from there by replacing the drivers from the system board on up until you've solved the problem.
May 07, 2009 | IBM ThinkPad T30 2366 Notebook
My computer is not booting up.
Try this,Start in VGA mode.Once started,update your video drivers and do a virus scan
To use a Safe Boot option, follow these steps:
  1. Restart your computer and start pressing the F8 key on your keyboard. On a computer that is configured for booting to multiple operating systems, you can press the F8 key when the Boot Menu appears.
  2. Select an option when the Windows Advanced Options menu appears, and then press ENTER.
  3. When the Boot menu appears again, and the words "Safe Mode" appear in blue at the bottom, select the installation that you want to start, and then press ENTER.
Safe Boot options loadTOCNode(2, 'moreinformation');
  • Safe Mode (SAFEBOOT_OPTION=Minimal): This option uses a minimal set of device drivers and services to start Windows.
  • Safe Mode with Networking (SAFEBOOT_OPTION=Network): This option uses a minimal set of device drivers and services to start Windows together with the drivers that you must have to load networking.
  • Safe Mode with Command Prompt (SAFEBOOT_OPTION=Minimal(AlternateShell)): This option is the same as Safe mode, except that Cmd.exe starts instead of Windows Explorer.
  • Enable VGA Mode: This option starts Windows in 640 x 480 mode by using the current video driver (not Vga.sys). This mode is useful if the display is configured for a setting that the monitor cannot display.
Please rate this a fixa
Jan 15, 2009 | Microsoft HP Pavilion DV6276US Notebook PC
Boot safe mode
to boot safe mode,
1. tap the f8 button while your computer boots...before your windows starts load and just after you press the power button.
2. a screen will appear it will give you the option to boot in safe mode, select it
Dec 28, 2008 | Toshiba Portege 4010 Notebook
Acer Aspire 5100 Wont Boot To Start....
Try booting in safe mode. you may want to first try loading the last known good configuration.
To get into the Windows Vista Safe mode, as the computer is booting press and hold your "F8 Key" which should bring up the "Windows Advanced Options Menu" as shown below. Use yourarrow keys to move to "Safe Mode" and press your Enter key. Let computer boot to safe mode and then shutdown. If problem continues then Start in safe mode again.
After you boot to safe mode then go to Control Panel, System, Advanced System Settings, Advanced tab should be at the forefront. Go towards the bottom of the popup (Startup and Recovery) and select settings. Then in the settings popoup uncheck Automatically Restart. OK and apply everyithing then restart computer. Let me know what happens.
Dec 18, 2008 | Acer Aspire 5100 Notebook
Windows XP fails to load and Computer will not start up.
Boot from startup floppy disks or CD-ROM, choose repair option during setup, and run Recovery Console. When you are logged on, you can run FIXMBR command to fix master boot record. This should solve your problem.
Sep 20, 2007 | HP Compaq Presario V2000 Notebook
Microsoft Windows XP Home Edition Logo
Top Microsoft Computers & Internet Experts
efs_perpends
efs_perpends
k24674
Jax Planet
Jax Planet
Are you a Microsoft Computer and Internet Expert? Answer questions, earn points and help others
