The wireless password for a router is established by the administrator of the router. This is whom you should ask for the password. Hacking into the router wont help you find it because the password is not displayed...it is a series of dots. You CAN, if you access the router setup, CHANGE the wireless password to something you can use - but if you are hoping to piggyback or hack onto someones service using their wireless password, you're out of luck.
You need to configure your router and use WPA encryption so that all accessing device can connect to it.
The obvious reason why the dell laptop can't connect is because of the WPA encryption set. It is different compared with what your router is actually broadcasting: WPA2.
So you can choose one of the 2 things to alter. Change your router's WPA2 encryption to WPA or change your Dell's setup to WPA2.
You could move your ps3 to the wall closest to their house. lol.
Assuming they are letting you piggyback their internet.
1. You could try pointing the antennas toward each other.
2. Another thing you can try it building a can-tenna. Sometimes you can use a pringle can or something similar to direct the antenna signals toward the source in a more focus fashion. I've gotten to it work in some buildings that seem to absorb wireless signals.
3. You could get a cheap router to boost your signal and set it up as a repeater/access point. Some routers do not offer the access point idea but you can flash them with firmware at dd-wrt.com; just make sure you pick a compatible router.
On the right bottom corner of your screen, you should see a message/icon about wireless networks.
Select the icon and you should see a list of wireless networks. Select your network, add your password (if you set up a password) and you should be connected.
An unsecure network just means that other people can "piggyback" on your wireless connection. It's not dangerous. In fact, I'm sitting in a place with my laptop right now, piggybacking on a signal.
The only possible downside is that if too many people ride on your signal for free, your connection could slow down. If you want help securing your router, I'll be glad to walk you through it.
If your neighbors know that your using their router, you might ask them to reset it. If they moved it, this could cause the weakening of the signal, walls drastically decrease a wireless signal. You might also refresh your wireless card by uninstalling the wireless drivers and reinstalling them.
I had the "error: inhibited" problem with my RCA 4-line Executive Series phone as well. When I checked the line from the phone to the wall outlet, I saw that it had come undone. After I plugged the phone back into the wall, it started working normally again.
I recommend substituting in a different, known-good telephone to see if that works. If you can't get any phone to work plugged into that extension, then the extension is dead. If another phone works but your RCA still will not, then the problem is with the RCA phone.
A similar idea is to try moving your RCA phone, substituting it in place of a working phone. If it works in room X but not in room Y, suspect the phone wiring running to room Y.
This phone employs a common but awkward means of wiring up lines two and four. Line two is wired to the wall by piggybacking on the patch cable used for line one. Line four is wired to the wall by piggybacking on the patch cable used for line three. A phone cord has four wires running through it, but a phone signal requires just two. The piggybacking technique leverages the cable's free pair to feed a second line.
The upshot is that one can test the wiring for lines one and three with a simple, plain phone. To test the wiring to lines two or four, some specialized knowledge is needed. In place of that knowledge, a different two-line phone which also piggybacks might be used.
That's detail you'll need to consider only if your problem is specific to line 2 and/or line 4.
Anyhow, I hope I'm not patronizing by being too simple. But, I had this problem too. It turned out to have nothing to do with the phone itself; the signal wiring to it was bad.
I realize that this feedback is a bit late and that you've likely already resolved your issue. Perhaps this feedback will someday help somebody else (since these Q&As are archived).
you can also check the settings of your wifi security. I would suggest you use WEP or WPA-TKIP (personal). You can also try considering this options below;
Getting an intermittent wireless connection can be attributed to the following factors:
a. 2.4 GHz wireless interference b. Wireless settings of your router c. Location of the devices d. Obstacles
You may also refer to the common causes of interference:
Window in brick wall 2dB Metal frame, glass wall into building 6dB Office wall 6dB Metal door in office wall 6dB Cinder wall 4dB Metal door in brick wall 12.4dB Brick wall next to metal door 3dB
In order for us to isolate the problem, please refer to the steps below:
1. Avoid obstacles.
a. Try to move the router to different locations in order to get better connectivity. We suggest placing the router on high location to avoid obstacles that may be blocking the signal.
2. Reduce wireless interference in the area.
a. Try to move the router away from devices that are operating on 2.4 GHz frequency like your cordless phones and microwave ovens. b. Try to move the router away from windows. Windows let in interference from the outside world.
3. Adjust the wireless settings on the router.
a. Please open any web browser like Internet Explorer or Netscape Navigator. b. Connect to the router by typing http://routerlogin.com/basicsetting.htm or http://192.168.1.1 in the address field and click Enter or Return key. c. For security reasons, the router has its own username and password. When prompted, enter admin for the Username and password for the Password, both in lower case letters.
Note: If it doesn't take password as the password, you might have changed it when you have run the NETGEAR Setup CD so please try other passwords. If you can't remember the password, you need to reset the router and run the Setup CD to reconfigure it.
d. Click on Wireless Settings under Setup tab. e. Change the Network name or SSID to your preference. f. Change the Mode to g and b only. g. Change the Channel to 11, 1, 6 or 9. h. Click on the Apply button. i. Reconnect your computer to the wireless network and see if it fixes the problem.
Note: If the problem persists, you may need to upgrade the firmware of the router.
4. Upgrade the firmware.
a. Please verify the router version and model either underneath or at its side panel. b. Go to http://kbserver.NETGEAR.com/downloads_support.asp and please select the model of the router. c. Click the appropriate version of the router. d. Select the link of the latest firmware. Click the button Right-click and Save to Download. Save the file to the Desktop.
Note: Please perform firmware upgrade with wired or Ethernet connection only. If your computer has wireless connection, then please disable it first.
e. Before upgrading, please write down all current settings since you need to enter them manually. f. Using the computer hardwired on the router, please access the router’s setup page again by going to http://192.168.1.1 or http://www.routerlogin.com/basicsetting.htm g. Click on Maintenance and then Router Upgrade. h. Click on Browse and locate the upgraded file in your Desktop. Then click on Upload. i. Please wait for the router to reboot.
5. After a successful firmware upgrade, you need to reset the router.
a. Please push the reset button at the back of the router and release after 30 seconds. b. Unplug the power adapter for 10 seconds and then plug it back in.
Note: Resetting the router will erase all the settings so it needs to be reconfigured afterwards.
The router can be reconfigured using the setup CD or by manual configuration.
