Expert
- Posted on Dec 03, 2009
Re: i cannot get any tv channels though my panasonic
This model only has an analogue tuner so wont receive anything if the analogue signal in your area has been switched off. either buy a new new with a freeview tuner built in or just use that one in conjunction with a freeview box.
Testimonial: "very helpful 5***** regards."
If your dvd recoredr is not set up to receive the digital channels, that is the reason you are getting no channels. I suggest trying an auto cvhannel scan, deleteing if its asks, any of the channels it may have now. You can also try a factory reset and tune in the unit, If nothing works, try the dvd player on another tv and the tv on another digital receiver to narrow what the problem could be. Check the channels and the inputs to make sure its on the correct channel for the dvd player. If all else fails replace the Printed Circuit Board with the RF tuner on it. The RF tuner is what the antenna plugs into. I hope this Helps. Good Luck.
