Question about Philips Televison & Video
Dvd is stuck inside and drawer will not open
I inserted a dvd into the player. It closed normally but sounded like something was stuck to the disk-- like part of the adhesive dot that held the disk inside the plastic case.
Anonymous
    New Friend:
Yes, it was a piece of the addhesive dot that was stuck to the back of the disk. I unplugged the unit (of course), removed the 10 screws holding the cover on the chassis and that exposed the disk in its tray. I could not manually open the tray still, but I was able to remove the tape dot from the disk while it was still in its tray. All is well now.
Posted on Dec 03, 2009
Cant open dvd drawer
Sometimes DVD player drawers get stuck closed because the disc inside isn't seated properly. At other times the player may have another problem. The first step in discovering if it is the disc or another issue is to remove the disc. Most DVD players have a secret eject button. It allows you to open the drawer when a disc gets stuck and cannot be ejected normally.
For this you'll need a standard size paperclip.
  1. Unfold the paperclip and make it as straight as possible.
  2. Look closely at your DVD player . Push the tip the paper clip into the small hole on the tray cover on the front of the Toshiba. The hole is on the right side of the cover.
  3. Press inward gently with the paperclip until you feel a slight resistance, then continue pushing to engage the internal eject button. The tray should pop open partway.
  4. Gently pull the drawer until it's fully retracted. Be careful not to pull too far.
  5. Remove your disc from the drive.
  6. Before you reinsert another disc, use the remote and/or buttons on the player to close the door, and reopen it. You can also press carefully with your fingers. If you cannot open/close the drawer normally at this point, do not put in a new disc until you have repaired the problem.
What You Need
Dec 09, 2013 | Toshiba SD Computers & Internet
Why can't we get the dvd to eject?
Possibility 1 -
The laser light inside the DVD player is most probably no longer aligned and cannot read the beginning of the disk. Therefore it keep on trying to find the first line but it can't.
Possibilty 2 -
Your husband entered a pirated copy and sometimes the first few tracks are unreadable due to the lower quality of DVD-R used and it jams the laser light inside the DVD player.
What needs to be done is to unplug the DVD from its source and gently pull open the DVD drawer in order to remove the stuck disc inside. Once that is done, power up the unit and press on the "eject" bottom so that the drawer can close itself.
Good luck.
Aug 16, 2012 | Samsung DVD-V4600 DVD Player/VCR
It will not let me insert a disc and when I press the eject button, it sounds like it is going to eject a disc and then it makes a weird noise for 5 seconds. Then, it will say CLOSE for a bit. I got one...
It sounds like you have 2 disks stuck in there. TV repair shop, or try shaking the dvd player lightly while dvd is trying to open. You may need to help open the door, but too much effort could cause harm.
Jul 08, 2011 | Samsung BD-UP5000 Blu-ray and HD-DVD...
My draw will not open
Hi, If you hire sound of motor (when you push the switch) who open the door then is rubber band on wheel inside DVD, or cd is stuck inside. In that case you can hook door with something and pool up easy! If no light on displey, or don`t hear motor (when you push the switch) then is electronic circuit in DVD, then you must go in service.
Good luck.
Feb 27, 2011 | Philips DVDR3440H DVD Recorder/HDD...
The dvd drawer won't open. it is "stuck" closed.
Hello
A stuck drawer indicates a jammed mechanism or the presence of a mechanical drawer lock.
Locate your DVD player's manual Eject button. It is usually a small hole located underneath the DVD drawer.
Insert a stiff wire-such as a paperclip or safety pin-into the hole. Push gently and the drawer should open partway. Gently pull the drawer the rest of the way open.
Nov 23, 2010 | Denon DVM-1805 DVD Player
DISC DRAWER WILL NOT OPEN
First, start with power cycling the player. Turn off the player and disconnect the power cord from the wall socket. Leave it unplug for about 5 minutes. Turn the player back on and try to open the drawer.
If same problem occur, then follow the steps below:
1. Turn off your DVD player. You do not want to risk electrical shock while working with it.
2. Locate your DVD player's manual Eject button. It is usually a small hole located underneath the DVD drawer.
3. Insert a stiff wire-such as a paperclip or safety pin-into the hole. Push gently and the drawer should open partway. Gently pull the drawer the rest of the way open.
4. Remove the DVD and see if there is a problem with it. Most DVD player drawers get stuck when a DVD is warped or the label is starting to peel. If the DVD is warped, discard it. If the label is peeling, remove the label.
5. Turn your DVD player back on. If it gets stuck again on a different DVD, then the problem may be with your DVD player rather than with your DVDs.
Mar 21, 2010 | Panasonic DMR-ES10 DVD Recorder
H02 Error after inserting a dvd disk
The trouble started with an error to close and open the DVD drawer. It indicated "close" when the drawer was open, or "no disc" when the DVD was inside, and I had to try many times before I get the right response and go on with the procedures.
But then it also started playing just a few MP3 tracks and stopping to work, showing again the inserted DVD data. Later H02, and then H07 and STOP. It doesn't even start playing stuffs, movies or MP3 tracks!
Aug 11, 2008 | Panasonic Televison & Video
My disk drive
Under the drawer is a little latching metal clip - you can use a small screwdriver to gently operate the latch, it is probably just stuck in the open position.
Mar 15, 2008 | Dell Inspiron 6400 Notebook
Dvd player
First, make sure the DVD Recorder is completely disconnected from the Main Supply.
Then, if you look on the base of the unit, (just underneath the front of the Disc Insert/Eject Tray), there is a small slot, (approx 25 x 8mm), in which you can see a small, white, plastic lever probably situated near the right-hand side of the slot.
Then move this lever gently to the left, and then turn it on and the tray opens by pushing the button.
Jan 14, 2008 | Televison & Video
Koss KD365 DVD - Says No Disc
Make sure the disc is spinning. This might sound crazy but try turning the whole player upside down and see if it plays.
Jan 02, 2008 | Koss KD365 DVD Player
Televison & Video Logo
550 people viewed this question
Top Philips Televison & Video Experts
matt martin
matt martin
Muntejaya Ginting
Muntejaya Ginting
Are you a Philips Televison and Video Expert? Answer questions, earn points and help others
