An ide 120G WD hard drive will not start up and is not recognized in the CMOS. Tried changing power connector to drive and drive cable. Drive appears dead. never made a sound.
click start control panel administrive tools ,computer management ,device manager look through all of your devices if you see a yellow question mark?or exclamation mark ! or red x right click to reinstall drivers or if you can see your usb but its not working ports(com&lpt)right click update driver if your computer came with a motherboard disk the drivers could be on it sometimes the wires inside the cable will be damaged due to bending or stretching or placing heavy equipment upon the cable, just replace the cable of the hard disk, when you plugged the external disk drive you got that windows could recognize the USB device change the cable everything should work fine again, check the USB leads that attach to the motherboard usually red-white-green-black make sure they are securely seated and have no dust build up on them dust will cause static and a lot of unforeseen problems also make sure the computers Ram and Cmos battery are securely seated hope this helps
You have to make IDE drive as slave. For this put the jumper to slave in IDE drive. Possibility of CMOS battery is rare, but you can confirm it by checking your system time in BIOS. If system time is ok then there is no problem in CMOS battery and you need not to replace it.
First, I recommend changing the USB cable. Try it on another computer to see if it works. If that does not work the next part is more complicated. You may not want to do it.
Open the box and remove the hard drive. Open your turned off computer and attach the data and power cables and support the drive next to the computer with no stress on the cables. Turn the computer on and see if you now have a new drive.
Problem: there are two kinds of drives: IDE and SATA. IDE has a wide 40 wire data cable and big flat 4 connector power cable. SATA has a small (usually RED color) data cable and a small power connector. There is now way anyone could confuse the two types.
If your computer and external drive match you can check the external this way. If the are opposite, you are snookered. Beyond these suggestions, there is not much more I can do.
I have successfully connected a older. 20 GB drive to a computer with a 2. sata connection on the mother board.
Buy trial and error I found that connecting a power cable to the converter and the hard drive was the only way to get the Bios To recognize the drive. Done sucessfuly with a 40GB drive as well, Set drive to master.
This problem often happens because of the cable, try to move the cable near the connector of your drive.
by this time access the devive manager, and check if there is changes in the list while you change cable's position, if so, your cable is defect.
I had a similar problem with my WD passport 320GB. When I connected it to my laptop it never showed up on My Computer even though the blue light on the hard drive came on.
Here is what I did:
Right click on "My Computer" and click on "Manage" and then "Disk Management",. you should see your WD hard drive listed. then click on "change driver letters and paths" and change it from the listed to another drive. I changed mine from G to F drive and it worked for me.
Sounds like you lost an ide channel, swap the ide cables around, primary to secondary and secondary to primary. and see if it recognizes the hard drives and not the cdrom.
I lost an IDE channel and had to install a sata hard drive or run the hard drive and cdrom on the same ribbon. If you run HD and CDROM on same ribbon set both to CS (cable select)
You probably need the change the jumper on the hard drive itself. The jumper looks like a thin little cap that covers a set of pins on the back of the hard drive. You should see it next to when you power supply connects and most drives will usually have a diagram on how to change the jumper from a slave to a master.
