You can use USB connection if you have original disk with drivers, other solution is a card reader (any inexpensive card reader will do the job)
You should be able to use a USB cable to connect the device to a computer, or take the memory stick from the device and use an adapter with your computer to access it like a flash drive or external hard drive. If you are using an SDHC memory card, you must buy a SDHC compatible adapter and meet the criteria for the adapter.
