Televison & Video Logo
Posted on Dec 02, 2009
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
LCD 42 crack under the screen
LCD 42'' flatscreen has a crack on the left side, screen is white with rainbow lines going up and down. Can this be fixed?
Dave Naylor
Level 3:
  • Master 834 Answers
  • Posted on Dec 02, 2009
Dave Naylor
Master
Level 3:
Answers
834
Questions
Helped
223412
Points
2476
Your screen will need replaceing the crack will only get larger on a 42 inch set it is going to very pricey
I have a hisesense 40" lcd lked tv.i grabbed it fron the top and my finger touched the screen.now its has about 12"black uneven spot and in the spot i have rainbow lcolor lines..plus one blue vertica
It sounds like you cracked the screen. If it is cracked, you cannot fix it. Your only options are to replace the screen (BIG $$$) or buy a new set. If you can email me a pic of the TV I can tell you for sure if the screen is cracked. LCD screen are very thin, about as thick as a dime and it doesn't take much to crack them.
[email protected]
Hello.I have a great 52' LCD Sanyo tv. It is damaged. The screen is not crack or broken but when I turn on the tv it looks like a broken window and there are rainbow lines verticle down the screen....
The underlying LCD panel has broken. this can happen on many devices and is often a result of a drastic temperature change. the only option is to replace the screen ether yourself or have it done at a local tv repaire center. if the product is still under warranty it should be replaced by the provider
Rainbow lines and no picture
NEW YSUS AND BUFFER BOARDS ARE NOW NEEDED THE YSUS IS THE BIG BOARD IN THERE VERY LEFT HAND SIDE ONCE BACK IS OFF BIG BOARD WITH 1 BIG HEATSINK,, THAT AND THE BUFFER BOARD PUSHES INTO THAT WITH TWO BLACK CONNECTION TO THE YSUS REMOVE BOTH BUFFER IS FIDDLEY,,NEED TO REMOVE 4 RIBBON CABLES ATTACHED TO THE SCREEN B4 HAND,,
6871QYH053B IS YSUS MODEL BUFFER U WILL ALSO FIND ON EBAY.
So i turned my ipod on this morning and about a third of the screen has these lines of color going down it, there is a dent at the very top of the screen and a crack going across part of the screen, it...
What happened is the LCD has cracked. Normally the molecules in an LCD are lined up parallel to each other. When an LCD (Liquid Crystal Display) breaks the liquid between the two sheets of display glass spread causing the molecules to loose that parallel orientation. That's where you get the colorful display. You can press on an LCD and cause this to happen without any damage (though I wouldn't recommend it to often).
Second explanation.
Rainbow bright has a thing for you and she left you a "Rainbow Message" on your Ipod. She just hit it a bit too hard with the "Rainbow Wand" ":)......
As long as you don't care what it looks like then don't worry about it. In ten or twelve years when you spend all the money you saved by not buying the next greatest gadget to come out on a ski vacation in Whistler/Backcomb. You can call all your friends and ask them "HOW YOU LIKE ME NOW"?
Before you buy a new one just remember to look around on-line for used or replacement parts for yours. They are out there and with a little bit of effort you can change out your screen.
I have an Ipod 6 gig mini that has parts to three different mini's in it. (Hey I'm a little hard on my gear. Plus working on a solid plate steel floor doesn't help.)
Hope this helps.
Sharp 46" 6 months old see rainbow colors from left to right
Did he change the big video board?The main backlight video baord that the prob.
Toshiba Laptop Screen
ur right the chime did it the screen ddnt crack but the piments in side are all jumbled ... the same happened when a relative got in a car accident... replacing will b needed tho
Horizontal ines---original post got wiped. Sorry.
leaky cap(s) in vertical circuit. shouldn't be more than $125 (plus taxes) parts and labour
2helpful
5answers
Line in middle of LCD screen
I too had a black line horizontally across the screen (on a 52" d62). It was brand new and was as if the screen had been "pinched" at the end of the line and it radiated outward (in my case, the "pinch" was at the extreme left and line went out to the right, like a crack).
Mine was a factory defect (right out of the box) and was replaced (2 yr now and no issues). This line of yours may have been there from the start and maybe you just didn't notice it?? Not a slam, just an observation.
Top Televison & Video Experts
Grand Canyon Tech
Grand Canyon Tech
 Grubhead
Grubhead
