Question about Brother HL-4070CDW Printer
Getting ink splatters on copies - Brother HL-4070CDW Printer
Posted by kharignph on
J Anderson
  • 159 Answers
That is normal with this printer. I own a Cartridge World ink and toner refilling store and we've found that the new Brother color laser machines (that take the TN-110 or TN-115) drop toner speckles onto the pages. This is because the cartridges were designed poorly. We do not recommend new Brother color laser machines for this reason.
Posted on Mar 08, 2010
Black ink printing on back of paper
Your paper feed rollers have some black ink contamination: wipe the rollers, all around, with slightly moist tissue paper until there are no more ink evidence coming off the rollers. To moisten tissue, warm water with a very small amount of Windex, dish soap or rubbing alcohol does wonder.
Also clean gently around the bottom of the print head assembly to remove any obvious splatters.
Hope i helps.
Sep 26, 2011 | Canon PIXMA® MP530 All-In-One Printer
I've tried printing twice and ended up with a paper jam. I cleared it, but also saw what looked like ink splatters inside the printer. I took the cartridges out and cleaned up the splatters and replaced...
This error message is displayed by the printer when paper is jammed in one or more locations. In such a case, users are recommended to remove the jammed paper from the specified location. The entire paper path must be checked for any pieces of paper. To stop the message, open and close the top most cover of the printer. Lastly, verify the flags and the sensors. If the problem persists, the cause of the error message could be a broken sensor or sensor lever.
Dec 06, 2010 | HP PhotoSmart C4280 Laser Printer
Ink splatters from new toner
Clean the drum unit cartridge and the charge roller unit.
Apr 15, 2010 | Minolta DI2510 Black and White Copier
Looks Like Ink splatter on my TI-83+ screen!
The screen has probably sustained a severe chock. It is very likely that it is damaged. For information about the availability of repairs in you area of the world, contact TI by email at [email protected]
Hope it helps.
Thank you for using FixYa and rating this solution.
Nov 18, 2009 | Texas Instruments TI-83 Plus Calculator
Black splatters all over paper
Have you changed the cartridge? Sounds like a bad seal after it was refiled or the nozzle went bad on the black ink. Try replacing the cartridge.
Jul 08, 2009 | Office Equipment & Supplies
Clean the ink absorber
The waste Ink absorber is a small, deep sponge, located where the cartridges rest when the printer is idle. Although you can technically reset the counter on the amount of ink held in the absorber, if you overfill it, over time you will start to have color staining on your cartridges, since your carts clean up on it after every cycle, at the extreme, you can have ink residue build up under your printer. Online printer supply shops can sell you a replacement absorber cheap.
. You will need some rubber gloves, rubbing alcohol, and a small prying tool.
1) Locate the absorber at the bottom right of the cartridge path
2) With gloves on, pry up the absorber (if you have the almost full warning, be prepared for some good splatter.)
3) In a small dish with a small amount of rubbing alcohol, shake the absorber around for a short while to moisten the outer ink.
4) Rinse the absorber in a metal sink (porcelain can stain) with more alcohol, then leave it to dry.
5) Replace and make sure the absorber is seated the same as when you took it out.
Then you want to reset the counter for the absorber.
1) Enter the Service Menu by keying = Menu,Scan,Copy,Scan.
2) Use the arrows to navigate to Service Menu Counter Access. then press OK.
3) Use the arrows to navigate to ABS-M Dot Count, press Copy.
4) Use the arrows until the count is zero, press OK then Reset.
5) For good measure, turn the printer off and on.
hope this helps
Jan 05, 2009 | Canon PIXMA iP1800 InkJet Photo Printer
Can not print
replace your cartridges clean the ink splatter sponge and make sure the cartridges are set in correctly and the printer is aligned this is crutial this will be in program specs
Jun 01, 2008 | Canon PIXMA MP150 All-In-One InkJet...
Black ink splattering the sides of the paper
remove ink cartridge wipe off print head area with rubbing alcohol
applied to a microfiber cloth
Jan 17, 2008 | Epson Stylus CX6600 All-In-One InkJet...
Brother HL-4070CDW Printer Logo
652 people viewed this question
CheckitRight
CheckitRight
James Cagle
James Cagle
Norman  J Weimar Jr
Norman J Weimar Jr
