Question about EuroTech Dishwashers
A E4 comes up water seems to be in bottom and there does not seem to be a drying mode...
  • EuroTech Master
  • 19,396 Answers
E4 is overfill protection error . If that happens on drain, then it is a drain problem.
Try first tripping circuit breaker and dry water in the tub using a sponge.
Check the drain well and the filter.
Ensure drain hose at the back is not kinked.
Access pump hose , undo it and look for blockage.
Check the water level device. This is usually a float switch, on some model you also have a pressure switch.
Posted on Dec 02, 2009
Fridgidaire FDB1250REC dishwasher comes on, fills some water in bottom then cycle stops but can hear motor turning on and off, water will drain when I try to start cycle again.
This seems to be the "anti flood" device at the base of the washer is triggered due to water at the base of the washer. This safety device consists of a polystireene float and a micro switch that detects water leaks/spills and automatically puts the washer in pump out mode. You need to find the leak (hose or clamp)dry the base and rectifythe leak it before the washer works.
Mar 22, 2010 | Frigidaire 24 in. PLD2850 Built-in...
Dishwasher will not fill- worked yesterday-sounds like it it trying to fill but water is not coming through-checked water valves under sink everything is in order-just no water
This seems to be that the Anti Flood system has triggered. This device detects water leaks / spills to the bottom of the washer and automatically puts the washer in pump out mode and shuts off the water inlet. The device is made up of a pollystireene float and micro switch that activates once the float detects any leaks / spillage. Dry water and check for leaks and this should solve the problem
Jan 23, 2010 | Kenmore 16522 Built-in Dishwasher
Bosch SHU 43C06 UC17 dishwasher the dishwasher is just draining with no water in the tub, and is not filling, it does not seem to begoing out of drain mode
water in the bottomof the base remove side panel and dry out the bottom base . the float is up . thats why its in drain mode. bosch old tech speaking.
Oct 10, 2009 | Bosch 24 in. SHU43 Built-in Dishwasher
E4 on the Woldgang Puck Electric Pressure Cooker
I fixed mine by elevating it 4 inches (E4) and dropping it on the counter. Something needed a little impact adjustment!
Mar 18, 2009 | Wolfgang Puck Electric Pressure Cooker...
There is water leaking from the bottom of the fridge
Hi!!! It seems that your drain line in the freezer section is plugged remove the bottom tray and check for ice or water if you do the unplugg your drain line with a hair dryer..good luck..
Jan 02, 2009 | Kenmore Elite 22.4 cu. ft. Bottom Freezer...
Kenwood dishwasher
E4 means overfilled which in practice means there is water in the tray at the bottom of the machine. Lean the machine forwards and the water will drain out and clear the fault code. chances are it will fill up again so if it repeats the leak will need to be found.
Oct 27, 2008 | Kenmore 46123 Stainless Steel Electric...
Belling IDW604
I found the solution myself. On the bottom plate, there is a float and a microswitch, when the water leaks onto the bottom plate it raises the float and activates the microswith which shuts down the machine and shows E4 on display. To get rid of the fault, you have to tilt the machine and drain the water from the bottom plate. Also make sure that there is no leak in the internal piping, if there is, the fault will come back as soon as the recess in the bottom panel fills with water.
Jan 12, 2008 | Belling 24 in. IDW603 Built-in Dishwasher
Beumatic
The E4 code means - Overfilled. To much inlet water. Remove water manually from the tank pan and try operating a new cleaning cycle. Good luck !
May 31, 2007 | Baumatic 23 in. BDW14 Built-in Dishwasher
Water leaks from inside of machine
TAWS850PQ0 WITH SAME ISSUE...found it to be the water pump located bottom front of machine...looking for replacement now...
Nov 13, 2006 | Estate TAWS850PQ
Dishwashers Logo
288 people viewed this question
Top EuroTech Dishwashers Experts
Marvin
Marvin
Are you an EuroTech Dishwasher Expert? Answer questions, earn points and help others
