Question about RCA L46WD22 Television
L46WD22YX5 RCA Flat Screen TV does not pick up ananlog stations all of sudden and sound goes in and out. Help! It's not the cable. The sound in the setup is set to maximum.
Posted by nyw94 on
Dave Naylor
  • 834 Answers
As of june 2009 there are no longer any anolog channels only digital
Posted on Dec 02, 2009
Mark Vincent Cowherd
    New Friend:
    Problem Solver:
  • 6 Answers
Not true only full power stations are full digital Here in southeastern Az. we recieve KVOA channel 4 (digital) on channel 20 anolog as of today 3/1/13. We use no converter box just rabbit ears at a distance of 72 miles.
Posted on Mar 01, 2013
I have a RCA TV Model L46WD22YX5 it will not read any channels with an antenna, HELP!
The whole USA (years ago now) converted to digital TV signal format from analog (which is what your TV uses), this means that the TV will not pick up any channels without a digital to analog converter box, you can buy them very cheap on eBay.
Nov 24, 2016 | RCA Televison & Video
We have a mitsubishi 1080 hd model ws-48311. We no longer have cable do we need a converter box for this tv to pick up free tv. Thank you
No. All you need is an inexpensive antenna to pick up local TV stations. If the stations are close, all you should need is something like this one: http://www.walmart.com/ip/RCA-Digital-Flat-Antenna-made-for-DTV/10542272
Sep 09, 2013 | Televison & Video
I have a RCA LCD TV model no. RLC3708A and when hooking it up when I took it out of box, I got to
I think you are confusing the channel on the tv and the channel of the cable company that is not something that you can pick up with the scan tv, scan tv is good for picking up local channel meaning air channel that we get with a antenna only not the cable chanel
Jun 24, 2012 | RCA Televison & Video
I have the rca L46WD22YX5 and I change the main board and the audio board because the tv loose the analog channels and no audio in any source also I cant change the source (av1av2hdmietc)What can I do?
Ouch my RCA does the same thing. Perfect picture but no sound and no analog channels. The only inputs the work are HDMI 1,2, and 3 so I have been using it as a computer monitor and running my sound the my surround sound.
Jun 29, 2010 | Televison & Video
I am having issues with my RCA L46wd22yx5. First cable is on channel 3. that channel keeps saying unusable signal. Video 1 is the DVD player. Same thing..Video 2 is the Xbox 360 same thing and the HDMI1 is...
Check to make sure that the individual cables are connected to the corresponding channel. For example, DVD player is connected to the "Video 1" output on TV. On the back of your DVD, the cable is plugged in the "out" output, going to your TV the cable is plugged in the "in" output(red, white, yellow) Are you using an RCA cable(red, white, yellow) for the units?
May 13, 2010 | RCA L46WD22 Television
L46WD22YX5 ONLY USED TWICE SCREEN INSIDE LOOKS
Yes it can be replaced but it usually cost more than the set is worth. I checked and the retail plus shipping from my distributor is about $700. That doesn't include labor to install. I would say it would probably run about $800-$850. Good luck and I hope it works out for you. Thanks for using fixya.
Nov 06, 2009 | RCA L46WD22 Television
L46wd22yx5 rca tv lost sound thru tv speakers, sound works thru home theater system...? no other problems seen...
Verify first in the audio setup on screen menu that the speakers are not set to OFF. Otherwise you may have bad power amp sections.
Nov 02, 2009 | RCA L46WD22 Television
RCA L46WD22 Television Logo
728 people viewed this question
Top RCA Televison & Video Experts
matt martin
matt martin
Are you a RCA Televison and Video Expert? Answer questions, earn points and help others
