I can't find any Windows 10 drivers for the SII DPU-414. According to the Technical Details tab at https://www.compart.pl/en/produkty/mobile-portable-thermal-printer-dpu-414/ , this thermal printer has drivers for Windows 2000, XP, Vista, 7 and 8. This suggests that the Windows 7/8 drivers are unsigned and will not work with recent Windows 10 versions. Microsoft insisted on signed drivers starting with Windows 10 Anniversary Update in 2016. (In 2016 there was a way to test an unsigned driver in Windows 10, see Google ("windows 10 unsigned drivers"). I don't know if these still work.)
I hope this helps. Filling out the form on the Compart.pl page Inquiry tab may let you get a link to the older drivers for the DPU-414. You can try using a virtual machine with Windows 7 or 8 under Windows 10 Pro or Enterprise, if you can find a license for the OS.
hello friend the error response 3 is recalibrate all system parameters. the resistance you have to have on hand are 10 ohms and 150 to first calibrate 1/2w begins receiver plate and then bipolar line.
ANSWER: Since it is a thermal printer it does not have a ribbon to replace.
Description: The
Seiko SII DPU 414 thermal Printer. For a compact desktop or portable
thermal printer, the DPU-414 is an excellent selection. It incorporates
the STP printer mechanism to ensure silent and high-quality printing of
characters and high-density graphics. And in quadruple-density bit image
mode, 640-dot (maximum) CRT display hardcopy is possible (with
horizontal vs. vertical radio of 1:1).
Product Specifications
Model DPU-414-30B
Printing Method Thermal serial dot printing
Number of dots/line 9 x 320
Paper width (mm) 112
Printing width (mm) 89.6
Max Speed (character/sec) 52.5
Paper path Curved
Character matrix (H x W dots) 9 x 7
Character size(H x W mm) 2.5 x 1.9, 2.5 x 0.9 (Condensed)
Number of columns 40, 80(Condensed)
Character type Extend Graphics Character set, Alphanumeric, International Characters, Katakana Character set
Interface Parallel (36pins Amphenol), Serial (9pins D-SUB)
Input buffer 28Kbytes
Command ESC/P * conformity
Cutting Tear bar
Operating Temperature (°C) 0 to 40
Humidity (%RH) 30 to 80(Non condensing)
Service life (line) 500,000 **
Dimensions (W x D x H mm) 160.0 x 170.0 x 66.5 (printer unit only) ***
i think it's a GAP problem, try to calibrate from the computer, if that's not solve the problem, find the CALIBRATE option on the LCD panel a. just follow the instruction to do manual calibrate
