Question about Apple iPod nano 3rd Generation
Small ipod firmware version:LD-2088-STD-1.1 CANNOT BE RECOGNIZED....HELP PLEASE
Posted by dibsdamwe on
Anonymous
    New Friend:
The memory is empty 0mb
Posted on Nov 11, 2010
Loko22
    New Friend:
My win7 format, my mp3, then every time i will listen, start the first music, mp3 xing ling, ver. LD 3088-std-1.1
Posted on Aug 23, 2011
Radu T.
    New Friend:
Http://www.upantool.com/liangchan/qita/2017/10318.html
Posted on Oct 29, 2017
Mp3 Ver: ld 3088 - std 1.1 does not recognized! help!
There are several reasons why your iPod Nano may not turn on or awake out of its "Sleep Mode." This can be extremely irritating if you wish to use your iPod Nano, but the device is constantly malfunctioning. You may not need to take your iPod Nano in to be repaired if the player doesn't turn on as normal. There are a variety of different fixes that you can attempt as a way to get the Nano to turn on.
Flip the iPod Nano's "Hold" switch to "OFF." The iPod Nano cannot be turn on if the switch is set to "ON." Reset the iPod Nano. Move the "Hold" switch to "ON" and then "OFF." Then, press down the "Select" and "Menu" buttons on the Nano. Hold those buttons for about eight seconds. The Apple logo will then become visible on the iPod Nano. Once this occurs, try turning the iPod Nano on once again. Connect the iPod Nano to an iPod charger or a computer that is turned on via the iPod Nano's USB cord. Charge the Nano for at least 30 minutes. Then, try to turn the Nano on. Update the iPod Nano's software. Connect the Nano to your computer via the player's USB cable. Open iTunes, and click the iPod Nano's name on the left part of iTunes. Click the "Summary" option at the top of iTunes. Then, click on the "Check for Updates" button that's positioned in the middle of iTunes. Follow the instructions that appear inside iTunes in order to install the updates on the Nano.
Feb 03, 2013 | Apple iPod nano 3rd Generation
I would like to downgrade firmware on iPhone 3G from 4.0 to 3.1.1 Please help
There is no 3.1.1 firmware version available for the iPhone 3G. 3.1.1 is only for ipod touches. To downgrade to 3.1.2 (http://modmyi.com/forums/downloads/firmware/6/iphone-3g-3-1-2-32353/) or 3.1 (http://modmyi.com/forums/downloads/firmware/6/iphone-3g-3-1-32183/), download from either of the provided links, go into iTunes and to your iPhone tab, shift+click on restore for windows, or alt+click restore on mac, navigate to the downloaded file, and open it. Your phone will restore to the downloaded firmware.
Dec 21, 2010 | Apple iPhone 3G
HOW TO DOWNLOAD SONGS FROM WED IN LD-2088-STD-1.1
well first of all you have to install a software called "iTunes" and after you downloaded iTunes then you can choose the songs on it.. after you choose the songs on it... you go to your itunes folder highlight all the folders, press ctrl+c (which copies the ones you highlighted) click itunes go to the music tab then press ctrl+v (which pastes the ones you highlighted) and there you have it you downloaded songs to your Apple iPod Nano
Sep 12, 2010 | Apple iPod nano 3rd Generation
Itunes does not recognize my itouch please help
Okay well the only way you can resolve your problem is by taking your iPod to your local Apple store they should do a swap. Sounds like there is a firmware fault.
Thank You, Apple Care Service And Support Nick M.
Jul 22, 2008 | Apple iPod touch
IPOD not being recognized
HI,
Please try to connect your Ipod in a different Usb port..make sure you check the connection..even i had the same problem for which i downloaded the Itunes software(updated version) and format my IPOD to original settings using the option available in it..Hope it helps you..Thank you!!!..
Jul 10, 2008 | Apple iPod shuffle Second Gen. Silver (1...
IPod Photo (30g) needs Firmware update
I beleave you should be able to use itunes to download the newest version and then restore (restore / upgrade) the ipod.
here are the instructions on how to perform a restore
How to restore your iPod:
For Windows:
  • 1. Make sure you've reinstalled the latest version of itunes.
  • 2. Open itunes, and then connect your iPod to your computer.
  • 3. After a few moments, it will appear in the source list in itunes.
  • 4. Select your iPod in the source list and you will see information about it appear in the Summary tab of the main itunes windows.
  • 5. Click the Restore button. You will be prompted with one or more restore options that may prompt itunes to automatically download of the latest iPod Software. The 4 possible restore options are:
    • Restore Option 1: Restore - Restores with same iPod Software version already on iPod.
    • Restore Option 2: Use Same Version - Restores with same iPod Software version already on iPod even though a newer version is available.
    • Restore Option 3: Use Newest Version - Restores with the latest iPod Software on your computer.
    • Restore Option 4: Restore and Update - Restores with the latest iPod Software on your computer.
  • 6. A progress bar will appear on the computer screen indicating that the first stage of the restore process has started. When this stage is completed, itunes will instruct you to leave iPod connected to your computer to complete restore.
  • 7. During the stage 2 of the restore process, the iPod will show an Apple logo as well as a progress bar at the bottom of the display. It is critical that the iPod remains connected to the computer or iPod Power adapter during this stage. Note: The progress bar may be difficult to see since the backlight on the iPod display may be off.
  • 8. After stage 2 of the restore process is complete and the iPod is connected to the computer, the itunes Setup Assistant window will appear asking you to name your iPod and choose your syncing preferences similar to when you connected your iPod for the first time.
May 15, 2008 | Apple iPod MP3 Player
IPod is not recognized
i have the seem probleme since i have installed a new firmware somone know where to find the original firmware ?
Dec 28, 2007 | Apple iPod MA446LL/A MP3 Player
Apple iPod nano 3rd Generation Logo
6,466 people viewed this question
Top Apple Audio Players & Recorders Experts
ThaMp3Doctor
ThaMp3Doctor
Muntejaya Ginting
Muntejaya Ginting
Geoff
Are you an Apple Audio Player and Recorder Expert? Answer questions, earn points and help others
