Question about SanDisk Sansa e260 MP3 Player
I am considering purchasing a Sandisc Micro SDHC 8Gb card for my Sandisc E260 MP3 Player. Will this be OK?
YourZEN
  • 820 Answers
Highest capacity memory card for the e200 series depends on the firmware version.
Consulting the Sandisk page gives next information:
Sansa e200 - verify the version of the player. To check, go to Settings > Info.
For 01.xx.xx firmware (e200 version 1) - up to 2GB microSD cards
For 03.xx.xx firmware (e200 version 2) - up to 16GB microSDHC cards
NOTE: Firmware is not interchangeable.
Posted on Dec 02, 2009
Testimonial: "Your quick response was very helpful. Thank you."
My sansa e260 does not recongnize my 4 gig sdhc micro card...why is this?
It's because the e260 is designed to work with microSD cards, not with microSDHC cards. You need to go with microsD cards 2GB and smaller.
Oct 03, 2010 | SanDisk Sansa e260 MP3 Player
Micro SD Capacity
The e260 will not recognize any microSDHC cards. It will only use microSD cards, which are limited to a maximum of 2GB in size.
Apr 14, 2010 | SanDisk Sansa E280 MP3 Player
My Sansa e260 can't read sdhc cards
From what ive found the max expansion card it supports is 6gb they might offer support for higher capacity cards with a firmware update but as of right now no they don't
Nov 05, 2009 | SanDisk Sansa e260 MP3 Player
Sansa e260 doesen't detect 4gb micro sdhc card
I will have to double-check the documentation that came with that specific MP3 player, but I know that some Sansas will only support upto 2 GB in the expansion slot.
Jun 09, 2009 | SanDisk Sansa e260 MP3 Player
Can 8GB micro SD be use in SanDisk Fuze 4GB mp3 player?
In order to use an 8gb micro sd, the device has to be SDHC approved. If you don't see an SDHC (Secure Digital High Capacity) logo on the device or on the owners manual, It isn't compatible. It will read up to a 2 gb micro sd card.
Dec 10, 2008 | SanDisk Sansa MP3 Player
Adding a 8GB MICRO SD card to the Sansa e260
I read somewhere that a 4 GB Micro SD card is the largest you can put in the SanDisk Sansa E260 expansion slot. It's maximum capacity is 8 GB, with internal + external memory put together. This is from what I've read. Hope this helps.
Sep 20, 2008 | SanDisk Sansa e260 MP3 Player
Write protect
The Sansa e260 can only use microSD cards. I believe the 4GB model can only handle the 1 or 2 GB cards. If you try to do any SDHC ones, then you may run into problems. I suggest right clicking the SD card on your computer screen after it pops up. Select Properties. There can be some help in this area. I suggest going to tools, and check for error problems.
Jul 17, 2008 | SanDisk Sansa e260 MP3 Player
My new 8Gb Micro Chip Will not except music
The chip may be locked - consult the documentation for details. Also, that card is too big for the e260 to read - 2GB or less.
Jul 01, 2008 | SanDisk Sansa e260 MP3 Player
Using a Micro SDHC card with Sandsa c250
I don't think that these support SDHC. Basically if a product doesn't say anything about a feature, it doesn't have it.
Jun 23, 2008 | SanDisk Sansa c250 (2 GB) MP3 Player...
MircroSD vs. MircroSDHC
well buddy sorry for the bad news but you better stick to the regular micro sd only cause they havent gauranteed the use of sdhc and secondly our sansa os can support only 2gb by default of card..so dont dream... but the good news is if you install rockbox to your player you could use a 8gb card with ease.. www.rockbox.org but your on your own with rockbox its an opensource software for mp3player and its developed by nearly 350 people accross he world
Jan 22, 2008 | SanDisk Sansa e260 MP3 Player
SanDisk Sansa e260 MP3 Player Logo
185 people viewed this question
Top SanDisk Audio Players & Recorders Experts
ThaMp3Doctor
ThaMp3Doctor
Muntejaya Ginting
Muntejaya Ginting
aliasger yq
Are you a SanDisk Audio Player and Recorder Expert? Answer questions, earn points and help others
