I guess you are looking for a MOUNT. Check for something like this at Amazon: http://www.amazon.com/Mount-It-Articulating-Mount-40-Inch-70-Inch/dp/B002CTV060
Based on what you have tried if a buzz or loud static via the speakers you have something wrong in the audio output circuit of the set--problem here is that circuit may be part of the Main board that processes all signal---a look inside---following the speaker leads back would lead you to that board.
A simple thing to do to narrow it a little (you may have done this) is with sound all the way off put your ear to the internal speaker--hear anything at all like a deep hum?
Depending on age of set and cost of the board likely bad it may or may not be a do it yourself repair.
This is not really a solution, but read on... I had these symptoms in my 42 inch Hitachi plasma also.When I took it in to get it looked at , I was told that dust was accumulating on and around the cooling fans.He gave it a quick cleaning ( vacuuming I assume) and it worked for a while then started malfunctioning again. Now I'm trying to decide whether to just pitch it or keep cleaning it myself.Hope this helps.
plasma tv units use a lot of power ,well into the hundreds of watts 9 some big screens use up to 800 watts to work)
I suggest that you consider a new led unit which uses barely any power and you will get a remote with it
hITACHI CMPAD14D 42 nel plasma ha una striscia nera di circa 3 centimetri runing ampio vicino al centro della tv da cima a fondo e che da qualche tempo si accende poi scompare
I think you have dry solder joints on the tv. Either on the chroma board, the vertical scan board, the line output board, or on the focus board. If you are going to do this yourself please take all necessary precautions against electric shock and discharge all capacitors that you can as a stray spark from one can cause damage to your tv and yourself. If you are not able to do this find a competant technician. Good luck.
