Question about Earthquake Sound PH-D2 Car Audio Amplifier
Fuse for power cable on earthquake PH D2
Ive had a earthquake PH D2 for many years not nowing what size power fuse it requires it doesnt say in manual. I have been using 100 amp fuse but think it requires stronger fuse due to its power.
Posted by g_arroyo73 on
Daniel Boyes
    Sergeant:
  • 436 Answers
I would go with a 40 or 60 amp fuse, this should be ok, you will hardly every run the amp to full capacity so its better to be safe than sorry.
Posted on Dec 02, 2009
Wiring power house phd2 mono amp to the earthquake 4 ohm speakers.
When i hooked up my bass knob the amp made my subs hum i unhook the rca but still humming unhook bass knob still hummin
Jun 12, 2011 | Earthquake Sound PH-D2 Car Audio Amplifier
Problem with Eathquake amp 2000w
the amp dose not have any such internal batery it is probly tosted call me 256-698-9903
Jul 05, 2010 | Earthquake Sound PH-D2 Car Audio Amplifier
Phd2 amp after repaired seems to lower output
Probably because when you repair amp's sometimes they don't run 100% when repaired
Jan 11, 2010 | Earthquake Sound PH-D2 Car Audio Amplifier
My amp earthquake ph d2 output mosfet number...rfp 40n10
Hello luistecnico2,
Those cross-reference OK. Go to www.mouser.com and do a search on both numbers. You'll find that one of them was manufactured by STMicroelectronics and is currently obsolete. The other is manufactured by Fairchild Semiconductor and is available at a cheaper price than the original.
Hope this helps.
Jun 20, 2009 | Earthquake Sound PH-D2 Car Audio Amplifier
Red light is on when i connect input cable earthquake 1000w amp
Cables are either shorted, or deck is putting out too much power for input on amp... many new head-units will put out up to 7v on the output jacks (RCA) the amp may only want to see up to 1v will need to consult head-unit manual for adjustment of outputs.
Jan 22, 2009 | Earthquake Sound PH-D2 Car Audio Amplifier
Numbers on these oiecen on one earthqkaue ph d2
hello their ! those parts are a secret of earthquake you need to send the
amp for service trust me!! .. theirs nothing you can do..
Jan 21, 2009 | Earthquake Sound PH-D2 Car Audio Amplifier
Protection light goes on on Power up
same thing happened to me a while back it is one of the reistors inside the amp, when you took the turn it anything bumped it or it fell it might have broken off, shake it and see if anything inside rattles, if so then you need to take it to a repair shop or some who can solder
Dec 14, 2008 | Earthquake Sound PH-D2 Car Audio Amplifier
Bass sounds flat when volume is increased
probably your power is too short, increase your gauge wire, and your ground wire of the amplifier has to be shortly as possible, and the positive has to be enough to support peak power, you can also put a big capacitor on the positive wire to give some more power while the bass peak.
Apr 26, 2008 | Earthquake Sound PH-D2 Car Audio Amplifier
Earthquake ph-d2
The PWM IC is an SG3525. Which IC are you calling the protection IC?
Nov 02, 2007 | Earthquake Sound PH-D2 Car Audio Amplifier
Earthquake Sound PH-D2 Car Audio Amplifier Logo
229 people viewed this question
Top Earthquake Sound Car Audio & Video Experts
Marvin
Marvin
Colin Stickland
Colin Stickland
Are you an Earthquake Sound Car Audio and Video Expert? Answer questions, earn points and help others
