This video give you step by step instructions;
Just done one.
Rremove the back and battery, remove 6 screws, note the position, silver screws at camera end, short black screws in the centre, long black screws battery end.
remove the plastic surround, the part with the camera lens and buttons on, this is a delicate operation as there are 2 hidden clips just above the centre screw holes, this requires the insertion of a thin lever between the plastic part and the black chassis, lever out gently (away from the chassis) to release the clips, remove the plastic surround, again be careful as the camera lens has a self adhesive rubber gasket. after removal of the plastic surround you will see 2 clips that hod the front panel to the chassis, gently lever these away to remove the cover. gently lever the LCD out from the top, again there is some self adhesive tape behind it, when the LCD is free gently lever the connector up, take note of how the flex circuit folds behind the LCD, refitting is the reverse of removal, careful when installing the screws, trun the screws anti clockwise until they drop into the original thread then tighten clockwise, do not over tighten or you will strip the plastic thread out.
One shud not fiddle with harware if one is not expert in doing out things.opening up screws in much easy then putting them in same places again.so my advice wud be that u take ur handset to near nokia care service centre.
