Question about Jabra BT4051 Bluetooth Headset
I need an owners manual for jabra model BT4051 headset
Posted by stewa062 on
Anonymous
    Novelist:
  • 190 Answers
You don't need one. After charging set, press and hold for several seconds until unit blinks repeatedly. Now it's on.
To turn it off, repeat procedure.
Press briefly to take incoming calls, or to place calls if your phone is voice activated. You should hear a beep after each press.
Use + and - buttons to increase/decrease volume.
Unit blinks once, intermittently, when it's ON. That is normal operation.
Note: It takes a few seconds for the connection to occur, after you initiate a call or take a call, and other sounds alert you when the connection is taking place. You'll learn as you go.
Posted on Dec 02, 2009
  • Anonymous Dec 02, 2009
    Last thing, when you connect it to your phone, the pass code is 4 zeroes. 0000.
Anonymous
    New Friend:
How long do you charge it/
Posted on Jan 11, 2010
Passcode for at & t bt4051
Try 000 or 999, what make and model BT headset do you have?
Nov 09, 2011 | Jabra BT350 Bluetooth Headset Headset
How do I sink my Jabra BT4051 with my Nokia 2720a . I do not have a manual any more.
Usually the following setup is required to Pair bluetooth headset with mobile phone. Your mobile phone should support bluetooth interface. 1. Put the headset in pairing mode ? Make sure the headset is off. ? Press the on/off/pairing button marked until the LED indicator light is solid blue. 2. Set your Bluetooth phone to ?discover? the Jabra device Follow your phone?s instruction guide. This usually involves going to a ?setup,? ?connect? or ?Bluetooth? menu on your phone and selecting the option to ?discover? or ?add? a Bluetooth device.* 3. Your phone will find the Jabra device' Your phone then asks if you want to pair with it. Accept by pressing ?Yes? or ?OK? on the phone and confirm with the passkey or PIN = 0000 (4 zeros). Your phone will confirm when pairing is complete. In case of unsuccessful pairing, repeat steps 1 to 3.
May 12, 2010 | Jabra BT4051 Bluetooth Headset
Pairing my blackberry pearl to jabra bt4051. it won't pair
Go to this site, and it will walk you through each step to connect your particular Jabra headset with your cellphone. Choose the headset, and then at the next page, choose your phone. Moving your mouse over each step will change the picture to what you should be seeing on your phone at each step.
http://jabra.pairx.co.uk/ Pls come back and let us know if this solved your problem.
Jan 03, 2010 | Jabra BT4051 Bluetooth Headset
Jabra BT4051 Bluetooth Headset Logo
752 people viewed this question
Top Jabra Radio Communications Experts
Anthony Ward
Anthony Ward
Mosaub Al Masri
Mosaub Al Masri
Ekse
Are you a Jabra Radio Communication Expert? Answer questions, earn points and help others
