Does your DVD player support that version of DVD disk? Not all players will handle DVD-R. Check the manual for compatibility.
Try recording to DVD+R then see if your player will play it.
Also, in what format (.avi, .flv, .mov, etc.) was the item recorded and is your player able to handle that format? Again, check the manual for compatibility.
check and see if the dvd player needs to be cleaned. you can pick up contaminates from other dvd's or cd's get yourself a dvd disk cleaner and run it thru seveveral times . and try to play your money then.
Try a different brand of blank dvd+r or -r. you will find that your dvd machine is fussy on what discs it plays. More exspensive dvd players are fussy with what dvd discs you put in, as cheaper dvd players would virtualy play most types of dvds.
Have you tried a different brand of recordable disk? Some do not record as well as others. Also......copied Dvds don't last as long as a factory recorded disk. If the disks are older disks....that may be it. Other factors are ....your laser may be weak or dusty in the DVD player. Do your disks have paper labels? BINGO! The paper has a different expansion rate than the plastic disk and will almost always bend the disk in the heat of the player......interrupting the playing of the disk....... usually about half way through it.......pop the disk into the freezer for a few minutes....then return it to your player to finish your viewing. Never use paper labels. Never leave your DVD player on unless you are using it.
Check your formatting on the DVD recorder, you need to finalize the disk to be playable on "any" player. That should solve the issue. Your JVC is looking for specific code as it reads the disc, when it's missing or not understood by your JVC it will either stop play or skip over it's interperated missing info. Hope this helps
I have an LG RH278 HDD/DVD Recorder, which was suffering from the problem that it could not play any bought DVD movies, which were previously working fine in that same player. It would however play svcd and DVD+R/-R movie discs.
The solution was to replace the laser tray. I found a new LG DVD BD lens LPC-815 laser tray here: http://www.laser-xh.com/en/?act=showproduct&proid=1147
I bought two for $5.50 each. Shipping was $32 (DHL), all together $45.10 (PayPal fees included). Delivery was fast and accurate within 3 working days (China - Sweden).
This is the unfortunate thing with copying DVD's. Unfortunately when a DVD is copied only certail players will play it back. I can burn a disk on my laptop and it will play fine in the laptop and on my Sony DVD player, but my Samsung will not read it. This is why when you burn DVD's it's important to find a brand that is read by numerous DVD players. Try using the Sony disks.
You can not view from the USB, since the USB port on the DVD player is ver 1.1. The transfer speed is to slow to watch a movie. Alternatively you can copy your movie from your flashdrive to the harddrive and watch from there. You will see what I mean with slow speed when you copy the movie. It takes ages.
It is very possible that the head alignment on your DVD recorder is a little out.
Also, make sure that you are closing the session after doing the recording (burn). If the session is not closed, the DVD will not be playable on other players.
