Question about Refrigerators
Refrigerator model TFX 20JA fan runs, but
Refrigerator model TFX 20JA fan runs, but freezer and refridgerator do not get cold. Is it worth repairing ?
Posted by lgfischer536 on
Eric Duda
  • 999 Answers
Depends on the reason for the no cool. it culd be as simple as a relay on the compressor and cost unde a hundred bucks or it could be major like a failed compressor. Only having it diagnosed will give you the answer.
Eric
Posted on Dec 01, 2009
Freezer is working but refrigerator will not get colder than 50 degrees
First out make sure you understand how refridgerators work. The freezer actually cools the refridgerator by means of the fan in the freezer. Check for ice build up on the freezer wall, if you have that you have a defrost problem, and should call a tech unless your handy them just use your model number, go to apdepot.com and enter the information and you will get an illistrated parts breakdown. Defrost timer, bi-metal or defrost thermostat and defrost heaters are the three parts of that system. Also now you could have something blocking airflow, a faulty cold control thermostat, or the fan in the freezer just may not be running at all.
If you need further help, I’m available over the phone at https://www.6ya.com/expert/jason_4570d45317834dd3
Apr 28, 2012 | Whirlpool GR9SHMXLB / GR9SHMXLL Top...
Freezer seems to be working fine, but the refridgerator is cool at best with the thermostat all the way down. I tried to defrost, but with no help. I think the fan in the freezer might be bad.
The only place that cools in a refrigerator is the freezer. The refridgerator side stills cold from the freezer via an air duct that runs from the freezer to the refridgerator. If your fan in the freezer compartment is not working your refridgerator side will not work. To replace the fan you will need to clean out the freezer including the shelving. Then remove the back panel all you need is a phillips screw driver. When the back is replaced the fan is at the top. It is held in by two screws that go threw rubber mounts on the fan braces. You will need to remove one ground wire and two electric wires on the motor its self. Make sure to unplug the refrigerator before starting the repair. good luck
Aug 28, 2010 | Kenmore Refrigerators
Refridgerator and freezer are not cold
hello sir/mam
if this is the problem please check the condensor of the refrigerator for its enough refrigrant.
Sep 14, 2009 | Whirlpool GB2SHKRLS Stainless Steel Bottom...
Ge fridg and freezer not cold; just cool; TFX 20JR; what could the problem be?
The problem is probably the defrost heater . This model is at least 12 yrs. in age . Pt # WR51X442 is the part number for the heater and harness kit . These parts are located behind the inside rear lower freezer panel . First , make sure the freezer fan is working . If not Pt # WR60X10008 is the freezer fan motor .
Sep 07, 2009 | GE (PSS26MSRSS) Side by Side Refrigerator
Bottom freezer freezes but refridgerator warm I think the model number is 823374 all the numbers are TP111AR003A8 TPD1380YXA K2299 823374 BCA
SOunds like the circulating fan is wearing out. This fan supplies the circulation for both the freezer and refrigerator. When this fan starts to wear out the air that is supplies to the freezer and the refrigerator is reduced to a point that the freezer will remain cold but the refrigerator is not. This fan assembly cost around $300.00 to repair/replace. Eventually it will completely stop.
Jul 10, 2009 | Refrigerators
Top refridgerator does not get cold but the bottom freezer works fine
Most of these have a fan that blows the cold air for the freezer into the refrigiator section. If the fan quits running you will experience your problem.
May 08, 2009 | Refrigerators
Kenmore Trio: the refridgerator is not getting cool
In the Freezer or Fridge compartment, there is the Evaporator Fan (& Motor) If the freezer is cold, the Evaporator fan motor most likely went bad. Check to see that when the compressor is running, so should be the fan motor. If not, you have to remove it & replace it. It is not an expensive repair unless you call for service on it. Make sure that you unplug the fridge when you replace the fan motor.
Mar 15, 2009 | Kenmore 73502 / 73504 / 73509 Bottom...
Door ajar alarm ringing and refridgerator not cooling enough
it sounds like either a defrost problem or damper door problem it is very well worth fixxing
Dec 28, 2008 | Samsung RS2630SH Side by Side Refrigerator
Warm fridge, cold freezer...
Listen for a fan running when you open the freezer door. May have to hold the light switch closed for it to come on. If you don't hear it then the fan is most likely bad. The evavorator fan motor is the most common repair on the trio's
Oct 06, 2007 | Maytag MFD2560HES Bottom Freezer French...
Refrigerators Logo
217 people viewed this question
Top Refrigerators Experts
Marvin
Marvin
john h
