Question about Tomtom ONE 3rd Edition GPS
My Tom Tom One 3rd edition battery will not hold a charge. I plugged it in to my computer and to my my 12V in my car but to no avail. The little light on near the on/off button on the top of the GPS turns green when plugged in. The sounds or jingle at start up are heard but no visual then it goes dead when unplugged.. Have plugged unit overnite but the same things happens all over again. Louise
Posted by b_manning on
Tom Chichester
    Top Expert:
  • Tomtom Master
  • 57,444 Answers
"(B)attery will not hold a charge". Replace it (if possible).
Posted on Jul 18, 2017
5 Related Answers
Anonymous
SOURCE: GPS Won't Turn On
My 510 was doing the exact same thing.
I called customer support and they helped me get it working again.
866-486-6866 is the number but here is what they had me do.
I had to push down the reset button for 15 seconds (the reset is in a small cut out near where you plug in the charger on the bottom.you will need to use a pin and you will feel the pin push in the button if you have it in the right spot.)
Then release the reset and hold down the power button for 10-15 seconds. the screen should come right back on.
If you need more help I suggest calling the 866# they are very helpful.
Posted on Mar 13, 2008
Anonymous
  • 158 Answers
SOURCE: Tom Tom 700 will not turn on.
Take a look inside your tomtom go . The photo's uploaded are of the GO and Go 300 / 500 / 700 10676aa.jpgseries so yours might not look exactly the same but will be similar to these. SEE PHOTO of the IC's highlighted RED. U24 is on the same side of the circuit board as the card reader. U25 is on the same side of the board as the power socket. These are the 2 chips / IC's that will be blown if reversed supply or more than about 6 volts has been applied. The blown components are usually blown due to attaching the WRONG charger or a faulty charger. ( the tomtom cigarette lighter leads often go faulty ) These IC's are very very small ( just 3.5mm across ) and the 10 pins ( 5 on each side ) are even smaller and very close together therefore normal soldering ability will not allow a novice to replace them. Special soldering irons are needed , magnifying glass or special microscope for electronics + a steady hand and good light. Its highly unlikely that a home repair is possible. Besides that , even engineers with years of soldering experience have great difficulty replacing these components and it often takes me 30 minutes just to replace one of these IC's and I have a steady hand. Most normal electronics repair companys cannot repair this type of component as they will normally deal with bigger things. So unfortunatly, your "corner of the street" TV repair shop won't be able to fix it for ya either. As far as I know TomTom don't repair these IC's either as its too fiddly and time consuming and for them not worth the effort. Your only hope is one of the repair people offering this service on online . Try a look on ebay under "faulty tomtom" .
Posted on Sep 15, 2008
Anonymous
  • 3 Answers
SOURCE: Tom Tom Go 710 - Won't turn on
not sure but try an other device on the car plug to see if it works??????????? could be the plug.
Posted on Dec 21, 2008
Anonymous
  • 36 Answers
SOURCE: Tom tom not charging up!
Battery's probably dead. If you're within warranty you can have it replaced by contacting TomTom. Otherwise, you can still use the device, you'll just have to have it always connected to the charger.
Posted on Dec 22, 2008
Andrew Moore
  • 19 Answers
SOURCE: my GO 720 tom tom won't start
You need to press and hold the power button down until you see the screen come on.
Posted on Jan 03, 2009
Can you tell me where is the reset button on tom tom 1 IQ
I'm a little confused about which unit you have, but the answer is simple enough..... If there isn't a small hole on the bottom of the GPS, then simply hold the on/off button for approximately 15 seconds -- until the unit restarts. The small "hole" that I'm referring to will be in the same vicinity as the connector that the cable plugs into. It should say reset right by it, if the reset button is there. If you do have a reset button on the bottom of the device, you'll need to use something to press the button. A paper clip straightened out a bit works perfectly.
The following lists are from Tom Tom's website. I hope this helps:
Devices that are reset by holding the On/Off button ico_open.gif
(GO x50, Blue&Me TomTom, GO x40,
XL IQ Routes, XL,
ONE IQ Routes,
Rider Pro, Urban Rider)
(GO x30, GO x20, GO x10, GO,
XL IQ Routes ², ONE XL,
ONE 3rd Edition, ONE 2nd Edition, ONE 1st Edition
TOYOTA, ECLIPSE, DAIHATSU, ECLIPSE II,
Toyota Aygo Connect Multimedia,
Start ², Start
RIDER 2nd, RIDER 1st)
Apr 29, 2011 | Tomtom ONE 3rd Edition GPS
Can the Tom Tom One 3rd generation be charged via the computers USB Connection?
You would be able to Charge the Tom Tom via USB Cable but it would take much more time as compared to a Standard Car Charger.
Let me know,if needed further assistance.
Hope i helped you.
Thanks for using ' Fixya ' and have a nice day!!
Apr 02, 2010 | Tomtom ONE 3rd Edition GPS
My tom tom one starts then shuts down. Can I fix this?
Sounds like your battery not charged fully. Check your charger unit , possibly fuse in plug faulty or cigarette lighter fuse in car blown.
Oct 14, 2009 | Tomtom ONE 3rd Edition GPS
My tom tom will not hold a charge.
  1. This can be sovled by buying a new battery from a place like batteries plus
Aug 31, 2009 | Tomtom ONE 3rd Edition GPS
Have tom tom for car,need to wire it up to m/cycle
I've wired my tom tom for use on a motor bike.
you CANT run 12v straight into the tomtom, you can see on the cig lighter plug it has a 5v output.
So I bought cheap lighter socket, it looks like plastic tube with the cable running out of the back.
So the wires run from the battery (via an in line fuse) to the cig adaptors, these are hidden in my side luggage bag to keep dry and up to the tomtom. job done
Apr 20, 2009 | Tomtom ONE 3rd Edition GPS
Tom tom will not switch on
try charging the tom tom fully and then reset while it is charging. a tom tom will not reset unless the new battery is fully charged which may take some time if you only have a car charger.
please give me a fixya! rating if this helped.
Apr 04, 2009 | Tomtom ONE 3rd Edition GPS
How do I reset to factory settings how to reset factory settings on tom tom one
Which Model of Tom Tom One ?
XL
3rd Edition
2nd Edition
make sure you're fully charged, remove any optional memory cards (depends on the unit) there should be a reset hole, place a straightened paperclip into the hole and press for 15 seconds.
140/130/125
make sure you're fuly charged, press and hold the on/off button for about 15 seconds until the unit restarts
Mar 18, 2009 | Tomtom ONE GPS Receiver
Dec 20, 2008 | Tomtom ONE 3rd Edition GPS
Tom tom one
I experienced the same thing. The battery was fully discharged. Plug the GPS into your USB port or car charger to provide power. Wait about 5 minutes for the battery to get a little charge, then try turning it on.
Sep 16, 2008 | Tomtom ONE 3rd Edition GPS
Tomtom ONE 3rd Edition GPS Logo
1,158 people viewed this question
Top Tomtom GPS Experts
k24674
Marvin
Marvin
Michael Thomas
Michael Thomas
Are you a Tomtom GPS Expert? Answer questions, earn points and help others
