Question about AT&T Lucent MLS-12D Phone
How do I set phone to ring at my extention? - AT&T Lucent MLS-12D Phone
    New Friend:
How to set my extension that no incoming calls would be ringing at my extension? Panasonic KX-T7730
Posted on Oct 24, 2013
Partner, all releases.
Examples
Receptionist Call Routing. If you want calls to be answered by the receptionist first, set the lines at the receptionist’s extension to Immediate Ring and the lines at the users’ extensions to No Ring. (This is the factory setting)
Receptionist Backup. If you want all calls on a line to ring directly at users’ extensions -with the receptionist providing backup -set the line at the users’ extensions to Immediate Ring. Then set the line (or lines) at the receptionist’s extension to Delayed Ring. An incoming call that is not answered by a user within 20 seconds will also ring at the receptionist’s extension.
Programming
To change the way outside lines or pools ring at an extension:
  1. Press [ Feature ] [ 0 ] [ 0 ] [ System Program ] [ System Program ] [ Central Tel Program ].
  2. Enter the number of the extension to be programmed for Line Ringing. The green lights next to the line or pool buttons on the phone show the current Line Ringing settings for all lines assigned to the extension. (If a line is not assigned to a button, the green light next to the button is off.) The following ringing options can be shown by the green light next to the line button.
    • Immediate Ring - on steady
    • Delayed Ring - flashes slowly
    • No Ring - flutters quickly
  3. To change Line Ringing for any line, press the line or pool button until the button light shows the correct setting (the setting for the currently selected line or pool also appears on the display).
  4. Continue programming or exit programming mode.
Posted on Dec 01, 2009
2 Suggested Answers
consultel1
george peters
  • 860 Answers
SOURCE: m7310 rings on 2 extentions
Sounds like the main phone(221?) has an answer dn key on it.
To delete the answer dn key you need to enter programming by pressing the feature key followed by **266344.When prompted to enter the password enter 266344.
The screen should say TERMINALS&SETS. The 4 top line/feature keys are now used for programming.
At the terminals&sets prompt, press the show key (top right arrow). The display should now ask for an extension number. Enter extension number you wantdelete the answer dn key from.i.e. if entension 223 is also ringing on 221 enter 221.
Press the show key (top right arrow)
The display should sat LINE ACCESS
Press the show key (top right arrow) .
The display should say LINE ASSIGNMENT.
Press the next key (bottom right arrow) 4 times .
The display say ANSWER DNs.
press the show key (top right arrow)..
The display should ask for an answer dn number.
Press the SCAN key (one of the three soft keys near the display)
The extension that was ringing on this set should be listed here.
Press CHANGE til it says UNASSIGNED.
Press the release key when finished
Posted on Mar 26, 2009
  • 6073 Answers
SOURCE: I need to make one
If the do not disturb feature is in use, try pressing Feature 0 1 (this requires a button with lights). If you were automatically forwarding calls from this extension, press Feature 1 1 then dial the extension number twice.
If you need to increase the ringer volume, then press + or up arrow when the phone is idle or ringing and the handset is in the cradle.
The manual for some Avaya phones are available here: http://support.avaya.com/css/Products Look under P for the Partner series manuals.
I hope this helps.
Posted on Feb 14, 2011
How to set delay ring Panasonic KX-TA824
First assing the flexible ringing day, night, lunch in programs 408 to 410, the assign the delay ringing for the extensions you want in 411 to 413.
Jan 25, 2014 | Panasonic KX-TA824PK Phone
Turn off Ringer For External Calls Only
If you use strata emanager it would depend on how your system was set up. One way is to go to Advanced configuration tab Station tab, multiple call group tab, click on the group number (far right), then member tab and select extention and ringing option. Another way is to go again from the advance configuration tab, then assignment tab select the extention number on the right select key assignment tab, and on the incoming extention line double click it nd select no ring.
Jun 11, 2009 | Toshiba DKT3020SD Corded Phone
M7310 rings on 2 extentions
Mar 26, 2009 | NorStar Meridian M7310 Phone
Multiple problems
When you dial Feature 981 is there anything displayed on the set... something like Inactive?
Sounds like the Call Pilot is failing...
Mar 03, 2009 | NorStar M7324 Telephone
Ring count between automated attendant and default extention
On extension 10 or 11, press Feature 00, left intercom twice, #506, mode 1, line 01, number of rings 0, do the same for all lines.
#321 to change a number of rings before individual VM picks up
Feb 16, 2009 | AT&T Lucent MLS-12D Phone
My Phones only ring twice before it goes to VoiceMail
What you can do is go into the management console for your system and find the forwarding this is under extentions option 2 fwd/dnd select your extention number and on the bottom option FWD No Answer Time (s) set it to 10 or more and this will change the number of rings.
I use a KX - TDA600 PABX so I hope this helps
Jan 06, 2009 | Panasonic KX-T7630 Corded Phone
Forwarding calls between extensions
Yes, press Feature 4, then enter the extension of the line you wish to forward the ring to. You can also go into the phone configuration to forward after a set # of rings. To ring another extension at set times you will need admin access.
Jul 02, 2008 | Nortel Meridian M7208 Corded Phone
Norstar Phones - Turn off ringer on phones
You have to go in to programming and set the phone in the shop to ring on line 3 only and the phones in the office to not ring on line 3.If you don't know how to go in to programming please inform me.
May 14, 2008 | NorStar M7310 Corded Phone
Direct line ring on my extention
CALL A QUALIFIED TECH TO COME OUT AND PROGRAM IT FOR YOU AS TURNING OFF DIRECT DIAL IS A SYSTEM PROGRAM NOT USER
May 11, 2008 | Panasonic KX-T7730 Corded Phone
Ring tone problem
MP3 format file are for you to listen to.
.mid, .aac, and .amr file extentions are ring tones.
You can download ring tones from:
http://www.zedge.net/
Jan 07, 2008 | Nokia 5300 Grey Cellular Phone
AT&T Lucent MLS-12D Phone Logo
2,250 people viewed this question
Top AT&T Lands Phones Experts
Ekse
Marvin
Marvin
Are you an AT&T Lands Phone Expert? Answer questions, earn points and help others
