Quantaray 28-200MM F3.8-5.6 Lens for Canon AF Logo
Posted on Dec 01, 2009
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
I have a Quantaray 28-200mm lens that I used on my old Nikon slr and I want to use it on my Canon dslr but the lens is way too big for the camera body. Clearly I'm a novice... Is there a mount I can buy that screws on the lens so the **** end can fit on my new camera body? I have a Canon Rebel xsi. Thanks!
Anonymous
Level 2:
  • Expert 302 Answers
  • Posted on Jan 03, 2010
Anonymous
Expert
Level 2:
Answers
302
Questions
Helped
135770
Points
500
The short answer is no.
The Long answer is maybe. You'd have to call some stores that carry the Quantaray products. Get phone numbers for the distributor, warranty repair shops, and maybe Quantaray home offices which may be in another country. Then you can find out if they still have the mounts for those lenses in stock, can it be done, where to send it, and how much. Mind you, they may have to totally change the electronics and the motors inside the lens too.
How to mount Quantaray 70-300mm F/4.0-5.6 Zoom Lens in Sony Alpha DSLR?
This 3rd party lens (like all of them) makes lenses specifically to fit Nikon, Canon, Pentax, Minolta, etc. camera body mounts. Each has a style mount that is unique. You can not simply mount a lens made for use on a Nikon body on a Sony body.
In order to use this lens, it MUST be the model designed for use on a Sony camera. Functionally, the lens will be nearly identical on any camera it is designed to fit, only the mount (the portion that actually mates to the camera body) differs from one lens to the other.
If you bought this lens without specifying it needs to be used with a Sony camera body (and it is for a different camera) it will NOT mount. Determine if the lens is indeed designed for a Sony camera body. You may find additional letters & numbers on the lens that can help you determine which camera body brand it fits by plugging the number into Google for a search. Additionally, the Quantaray brand is / was a Ritz Camera "house" brand. You could probably bring it to one of their stores and learn all you need to know about the lens there.
2answers
Can I use my Quantaray 28-80mm lens with a new Nikon D3000?
Quantaray makes their lenses available for a variety of camera brands. If the lens has a Canon mount, then no. If the lens has a Nikon mount, then yes.
Also, bear in mind that if the lens does not have an internal focusing motor then you will not get autofocusing with the D3000. Everything else will still work, but you'll just have to focus manually.
I found a Quantaray 55-52 mm step down ring (Manufacture # 241664614) on Wolf Camera's website that I am interested in purchasing, but want to make sure it would work for me. I have some close up...
No. The 55-52mm step-down ring will let you attach a 52mm attachment onto a lens with a 55mm thread. You want a 52-55mm step-up ring.
Mar 21, 2011 • Cameras
1helpful
Do the old AF lenses for the Nikon N60 SLR fit the new DSLR cameras
Hi ericm675, Yes they will. What you run into is were one uses a auto focus lens on a newer digital such as a D40. Some of the new digital cameras do not have the drive gear to turn the autofocus on the lens. Those newer cameras use electronics. Look on your camera lens mount at 7:00 you will see the drive pin. Look on your old autofocus lens you should see a slot where that pin fits. Hope this helps you.
WHICH LENS WILL GIVE THE SAME RESULT OF 50 MM LENS IN FILM MODEL
To figure the equivalent coverage comparable to a film camera, multiply the number of mm by 1.5. Example: a 50mm lens will be like a 75mm lens on a digital camera.
2answers
Quantaray 70-300mm SLR lens does not work with Canon DSLR STi
If it doesn't work then sorry that is how it is. I heard is not really a good reason, I hear a lot of things most is not true.
Cameras compatible with Quantaray AF 70-300mm lens
Depending on how new your Minolta SLR film camera was, the lens may or may not work on a Minolta Digital SLR. In many cases, a lens with the correct mount (in this case, a Minolta mount) can be used on the same brand of camera in the digital format.
One thing you should know is that DSLR sensors are, generally speaking, smaller than the size of a 35mm film negative. Long story short, that means that your lens will have a magnification factor on the DSLR. Usually, it is in the range of 150%, so a 70-300 lens from a film camera would cover 105 to 450 on a Digital SLR.
To be sure about the mount, you'll need to seek advice specific to Minoltas -- probably best to take your lens to a local camera shop and see for sure if it fits and what features will work (aperature, auto-focus, etc) and which won't work on the DSLR.
3answers
I have a Quantaray 70-300 f1:4-5.6 LDOMacro. I have been using it with Minolta QTsi Maxxum SLR. I am looking into getting a Digital SLR that I can use my lens with. Is there one out there.
http://shop.ebay.com/items/_W0QQ_nkwZminoltaQ20canonQ20
adapterQQ_armrsZ1QQ_fromZR40QQ_mdoZ
here is a link to an ebay search for minolta to canon eos adapter, they sell for just about every camera. i know it sucks, buying a new camera that wont work with your favorite lens, but i think you might be better served focusing (couldnt help myself) on camera features and pricing. i own a canon dslr and love it. sigma has a cool dslr. it has a three layer image sensor, with a removable on sensor ir filter. the ir filter thing is really cool.
SLR to DSLR
You can use it, but it will not autofocus on your D60. It will set exposure properly, but you will have to turn the focus ring.
1helpful
Lens
Quantaray is a private label lens made for Ritz Camera. They make this lens to fit several different camera brands including Nikon and Canon. The only ones that will fit a Canon camera body are the ones with the Canon EOS mount. If your Quantaray lens doesn't have an EOS mount, then it won't work on your Canon camera. You can take the lens to any Ritz Camera location and they can help determine which mount it has, and which cameras it will fit.
Top Quantaray Cameras Experts
ZJ Limited
ZJ Limited
Grand Canyon Tech
Grand Canyon Tech
Tony Parsons
Tony Parsons
Are you a Quantaray Camera Expert? Answer questions, earn points and help others
