Question about Wolf Range WKGD-2 Gas Double Oven
Soap and water just don't cut the built up grease in my wolf professional electric convections. help!
Posted by omama_fritz on
Anonymous
    New Friend:
  • 25 Answers
Use de-greaser, soap, and brillo pad.
Posted on Dec 01, 2009
Probe light on convection oven stays on. Clock won't display. Oven still works though.
Sounds like the control board is not communicating correctly with the rest of the unit, consult a professional.
Aug 10, 2012 | Frigidaire 30" Built-In Single Electric...
I cleaned my electrolux oven for 3 hours and now my oven will not heat up any help please?
From what you have described sounds like you need to have the oven reset. Unfortunately, if resetting it at the household circuit breaker does not prove to be successful, then you will need a professional technician to pull the unit out of the cabinet/wall and reset it from the back panel.
Jul 31, 2012 | Electrolux 30" Built-In Single Electric...
White residue left after using self cleaning feature - I can't remove it with soap and water and elbow grease. What would work? This looks awful!!!
The residue your seeing is the remains of whatever was left in the oven when you decided to creamate in. Grease, food, etc was basically turned to has and then powder coated into the metal. Bit of advice for the future though, avoid using self clean mode not only for the scenario you have, but for your bank account as well. The temperatures the oven reaches in self clean exceed that of which the oven cavity can handle letting heat pass upward, usually damaging the lock mechanism for sure, as well as the control board and touchpad.
If you need further help, I’m available over the phone at https://www.6ya.com/expert/jason_4570d45317834dd3
Apr 23, 2012 | GE Profile JT952 Electric Double Oven
Oven temp will not change
Most ovens have BAKE, BROIL and yours might have CONVECTION. Turn each on independently. If all don't work its one problem if only one doesn't its another
Also is it the gas doesn't ignite or it ignites then no temp change (or electric gets to xx degrees but doesn't get hotter?
Sep 04, 2011 | Wolf Range WKGD-2 Gas Double Oven
What is the best setting for my viking on a 14 pound turkey, bake or do i use the convection broil?
Use the regular bake setting.... run the oven at 350.... the 14 lb. bird will take about 4-5 hours.....convection moves air and can tend to dry out the bird...
heatman101
Nov 25, 2010 | Viking 30" Professional Select Built-in...
How to clean the oven
The inside of the oven can be cleaned with regular soap and water. Dawn works well on built up grease. if you have very stubborn stains easy off makes a low fume oven cleaner, but try hot soapy water first. the outside can be cleaned with any stainless steel cleaner or window cleaner.
Nov 20, 2010 | Dacor Epicure EO127 Stainless Steel Dual...
Viking 27" Electric Oven Noise
Hello. The Viking does have fans which operate continuously to insure even baking. If it sounds like fans running, this is the convection fan operating. J.
Jul 01, 2010 | Viking 27" Professional Select Built-in...
Convection oven no longer works
Could be the fan trying to start, ,if there is a removable cover in the back of the oven, remove it and see if the fan is free to spin, could be a tight bearing , or it could be stuck with a build up of grease.
Jan 02, 2009 | Viking 30" Professional Select Built-in...
Wolf Range WKGD-2 Gas Double Oven Logo
185 people viewed this question
Top Wolf Range Ovens Experts
Harjeet s. bola
Harjeet s. bola
ray gallant
jenifer ronan
jenifer ronan
Level 1 Expert
Are you a Wolf Range Oven Expert? Answer questions, earn points and help others
