Question about XM Radio (XMP6000)
2005 Audi A4, XM factory installed; frequent signal interruption
I have a 2005 Audi A4 with XM factory installed. When I first purchased the car from the dealer, the XM worked fine, but over time, I increasingly experience intermittent signal interruptions. The signal interruptions occur on the open road, in areas without excessive trees or other obstructions.
Any suggestions on what the problem is?
Thanks
Posted by curtisschehr on
I purchased a used 2005 A4. No radio code provided. Where can I get the code in case of power disruption?
an audi dealer may have the code on record but as this can be changed by the owner(or anybody else)anyone with half a brain would have written it down inside the service booklet when bought new..
Jul 05, 2010 | 2005 Audi A4
Tip
How To Install Replace Change Headlights and Bulbs 2005-08 Audi A4
Learn how to install or replace the headlights and bulbs on a 2005-08 Audi A4
on Jan 27, 2016 | Audi Cars & Trucks
Tip
How To Install Replace Fog Light Assembly 2005-08 Audi A4
This video will show you how to install or replace the fog light assembly on a 2005-08 Audi A4
18034 code,i think is a bad conection, in the TCM,but where is it.my car is a audi a4 2005
Trouble code identification:
VAG type 5-digit fault code 18034 = EOBD type P1626 fault code:
Fault location = CAN data bus, TCM - no signal
Probable cause = TCM trouble code(s) stored, TCM incorrectly coded, wiring, matching resistor in ECM.
Jan 28, 2010 | 2005 Audi A4
Fault code p1672 or code 18080 2005 audi a4 1.8 t Both front fans do not operate. Installed new fan module.
That sounds like you have bad fan switch it reads the temp.of the coolant and sends a signal to the computer to turn on the fan.
Oct 03, 2009 | 2005 Audi A4
My 2005 audi a4 driver side window is stuck fully open. is there a way to open the inside of the door to take a look whats wrong?
This is a common problem in Audi's. The problem is a window actuator. It's made of plastic and breaks frequently. If you google it you can find it online for around $250. My mechanic charges around $300 to put it in. Its a pain to put in but worth the experience.
Aug 22, 2009 | 2005 Audi A4
How to connect a Blitzsafe AUDI/M-Link1 V.1B - iPod interface
I have the same problem. Did you get anyone to help you? I have the same car. A4 1.8T 2005 with the Symphony factory radio.
Jul 08, 2008 | 2006 Audi A4
Car Audio & Video Logo
Top XM Radio Car Audio & Video Experts
xxxxxx xxx
 Mikey
Mikey
Are you a XM Radio Car Audio and Video Expert? Answer questions, earn points and help others
