Question about John Deere 3010,3020 Tractor Basic Carburetor Repair
17 HP briggs & stratton not getting fuel - John Deere 3010,3020 Tractor Basic Carburetor Repair
Posted by eaglespr on
Roger Geer
  • 78 Answers
First change the fuel filter. Carefully pressurize the fuel tank to see if you have fuel flow to the carb. If no luck, depending on the yr. You may need to rebuild the fuel pump which is on the front of the carb and some models its on the side of the blower housing. This is not as easy as it sounds. I accidentally put one back together WRONG and destroyed it and I have 35 yrs experience at this stuff. I had to order a new pump body from briggs.
The diaphragm kit is part #693503 is for the 4 screw fuel pump and includes everything you need to completely rebuild the carb and fuel pump.
GOOD Luck
Posted on Dec 01, 2009
Which valve is the intake valve on a 17 hp briggs engine?
look at the valve s one is smaller than the other one this is the intake the big one is the exhaust valve
Jun 11, 2014 | Briggs AND Stratton Intek Briggs &...
Does a briggs and stratton 17 hp ohv have a fuel pump
Some model so and some are simply gravity fed.
Dec 31, 2013 | Briggs & Stratton Garden
Testing alternator output 17 hp briggs & strattonWhat's your problem?
To measure amps being delivered too the battary, connect a negative shunt to the battary negative terminal this will allow you to connect a multi meter and take a reading.
Jun 29, 2012 | Briggs & Stratton Garden
Brigss and Stratton engine getting to much fuel
I HAVE A BRIGGS & STRATTON INTEK 18.0 ,JUST FINISHED CUTTING THE YARD,WENT BACK ABOUT 20 MINS LATER TO PUT LAWN TRACTOR AWAY. WILL NOT TURN OVER WHEN I TRY TO START, FUEL LEAKS OUT OF THE EXHAUST AND AROUND THE BOWL
Jun 19, 2010 | Briggs & Stratton Briggs Stratton Intek V...
How do I install a fuel pump on a model #31g777 0559 17 1/2 hp briggs and stratton engine?
remove the screws that hold on the fuel pump install new pump and torque screws to 16 inch lbs
Nov 17, 2009 | Briggs & Stratton Garden
Want a repair manual for a 17 hp briggs & stratton engine
A range of strip-down manuals for all Briggs & Stratton engines is avalable - I got mine from Amazon, but you can get them directly from Briggs & Stratton via their web site. They have a look-up system by model series, which ensures you end up with the manual that covers your engine.
Oct 01, 2009 | Garden
John Deere 3010,3020 Tractor Basic Carburetor Repair Logo
543 people viewed this question
Top John Deere Garden Experts
Dennis Key
Dennis Key
john h
Are you a John Deere Garden Expert? Answer questions, earn points and help others
