Question about Woods 201 cu. ft. Upright Freezer V2003RW3
Our upright freezer door will not seal tight with a vacuum anymore. The freezer fills up with snow from the air drawn in. I have defrosted it and cleaned the seal. What should I do now?
Posted by michaelreedd on
Gil Shultz
  • 3,388 Answers
That could be one of two things, one the door is not aligned properly and more important the gasket has failed and needs replacement. The snow as you call it is ice condensed from the atmospheric air that is getting by the gasket. You may want to check the door gasket and sealing surfaces especially in the area of the "snow".
Good luck,
Gilshultz
Posted on Dec 02, 2009
I have a very noisy fridgidare upright freezer causing snow on contents inside it?
Hi Lisa, thank you for your post! New freezers retain colder temperatures. Especially on hot humid days, moisture entering the freezer (when the door is opened) can form frost inside the appliance and moisture collection inside the unit. Reducing energy use to meet government requirements, defrost heaters have shorter run times. Light loads in the freezer also contribute to the problem.
Here are some tips to keep moisture low in the freezer:
Use your air conditioner to reduce humidity.
Arrange shelving and food items so air circulates.
Don't "overload" or leave the freezer empty. It should be at least half full.
Set the controls as recommended in the use and care guide. Manufacturers may suggest different settings for summer and winter.
Properly seal liquids and high moisture foods stored in the unit.
Open the freezer doors as few times as possible.
Clean condenser coils at least twice a year. Check your use and care manual for specific procedures. You'll save energy, too.
Cover pots and pans and use the range hood fan when cooking to reduce moisture in the kitchen.
Check and maintain door gaskets. A good door seal keeps warm moist air out of the freezer.
These tips will help control frost and moisture in your freezer, but won't always eliminate the problem, especially when humidity is excessive. If you have taken all necessary steps to prevent moisture and humidity, you may need to reach out to a professional for further diagnosis.
Hope this information helps resolve this issue.
Aug 22, 2013 | Frigidaire 20.3 Cu. Ft. Frost-Free Upright...
We have a frigidaire upright (ffu17m7hwd) which formed a lot of ice and we are in the midst of defrosting and don't want to experience this again. Can you assist please? Had to throw food out due to...
Freezer burn to food is caused by air & moisture in contact with it.
There should be a tight seal by the rubber gasket along all the inside edges of the freezer door. This gasket prevents unwanted hot moisture and hot air from entering the freezer compartment and causing ice build up. You can test the integrity of the rubber gasket seal by seeing how the freezer door will pinch a slip of paper in various spots around the freezer door. If the slip of paper pulls out easily, there is not a good seal at that spot. If that's the case (which I believe it is), the door gasket needs to be replaced. By the way, ice will build up over time because you need to access the food in the freezer, hence you will introduce moist air each time you open the freezer door.
Aug 28, 2011 | Frigidaire 20.3 Cu. Ft. Frost-Free Upright...
My Frigidaire up-right freezer used to make a sound when you closed it that sounded like the air was being drawn out. It doesn't make that sound anymore and there is ice building up at the top of the door....
either you need to put spacers under the door on the door pin to raise it up.you may need to bend the doon. or replace the door gasket
If you need further help, I’m available over the phone at https://www.6ya.com/expert/dude_653d05454b389bba
Mar 28, 2010 | Frigidaire 12 cu. ft. / 340 liter Upright...
Top coil in upright freezer icing up
its a manual defrost freezer, it is normal to ice up, if it is unusually more than you have noticed over the past 40 years, see if the door liner is cracked around the screws under the gasket, if so put some washers there to reseal the door liner
Nov 01, 2009 | Freezers
Self defrosting deep freeze not defrosting
The excess frost in those areas is probably caused by leaky door gasket seals. They should be tight enough to hold a dollar bill securely all the way around. A defrost problem would start on the coils behind the back cover inside the freezer and would also appear on the back wall before it did on the door edges.
Jul 13, 2009 | Amana 19.6 cu. ft. / 555 liter Upright...
Just defrosted my freezer and is akll frosted over
When you say it is frosted over, do you mean the interior of the freezer is frosted, or the evaporator coils?
A couple things to check for:
1. Is the door gasket making a good seal when you close the door? A good quick fix for a bad seal on the gasket is to rub a thin layer of Vaseline (the original jelly kind works best) on the rubber to help it stick and to fill any scratches that might be keeping it from sealing tightly.
2. Is the fan running on the inside of the freezer? The evaporator coil in the freezer needs a fan to blow air over the coils to keep them from freezing over. They don't run continuously, and on some units will turn off when the door is open, so try holding the door switch shut when you check.
3. Is the defrost cycle working? Frost-free freezers have a defrost cycle in which a small heater turns on to thaw any frost that has begun to form. To check the functionality of the heater and the defrost timer will probably require a visit from a technician... It would take a while to explain it here, but if check the first two and come up empty handed, post back. You will need a volt/ohm meter.
I would check the first two
Mar 24, 2009 | Whirlpool 16.7 cu. ft. / 473 liter Upright...
My woods upright freezer keeps frosting up at the top with several inches of frost. It is a manual defrost freezer. Any suggestions?
check your door seal, by closing the door on a strip of newspaper all round the seal. this fault is usually air getting inside the freezer, it rises to the top making thick ice or snow.
Dec 17, 2008 | Woods Upright Freezer MU07W
Door seal
i wouldn't worry about vacuum seal. door gaskets contain a low powered magnet around the entire face for "contact" seal, id look into perhaps something placed on one of the shelves or door blocking the door from closing as tightly as you remembered. if you have a problem with that gasket. it would have to be physically ripped and where it didn't make contact you would have an influx of warm air resulting in ice balls forming inside door liner adjacent to seal
Mar 03, 2008 | Amana 16.8 cu. ft. / 476 liter Upright...
GE Upright Freezer problem/door
The door seal is damaged or the hindge alignment have allowed the warm air to enter and the cold air to leak out the of the freezer. Look and feel around the door for the cold air and check the top and bottom hinges to make sure they haven't become loose. Look for tears also around the seal because this will do the same thing. Let me know what you find. JT
Oct 23, 2007 | Kenmore 20.6 cu. ft. Upright Freezer 24092
Woods 201 cu. ft. Upright Freezer V2003RW3 Logo
694 people viewed this question
Top Woods Freezers Experts
Muntejaya Ginting
Muntejaya Ginting
Marvin
Marvin
Are you a Woods Freezer Expert? Answer questions, earn points and help others
