If it does not fill then nothing else will work either.
First take off the hoses and check the screens going into the washer, they are usually right where the hoses hook up. Make sure they are clean and then check each hose to make sure you have water from them.
If that does not work then check that you have power to the solenoid valves. Theses are magnetic valves that open to let the water in. They are on the plastic valve body where the hoses hook.
If you have power there when you try to start the washer and no water then the solenoid valves are the problem. If there is no power there then the timer has probably gone bad.
There is a slight possiblity that the fill switch failed, but that usually fails and runs the washer over, not so that it won't fill. :-)
I hope that this will help you to solve your problem!
Thanks for using Fixya!!
Heatman101
If your washing machine will not fill, only hot or cold will fill or is slow to fill then read these tips. I have covered many of the things that can happen in these tips...
Washing Machine Problems No Water
Washing Machine Fix Washing Machine No Water
heatman101
