Question about Dell Inspiron 1200 Notebook
My Inspiron 1200 turns on but I have a black screen - no video. It began fading - now nothing. Is there anything I can replace?
Steve Allison
  • Dell Master
  • 5,569 Answers
For Ichand-
> then you are going to need either a LCD inverter or new LCD. They are not too hard to swap out, the inverter costs about $15,it is mounted in the lid, below the LCD, and the replacement LCD about $80.
Didn't you mean backlight rather than LCD?
Take an angled look at the screen with the unit turned on; if you see a 'ghost' image, the LCD itself is functioning, only the fluorescent backlight or its inverter is toast.
Posted on Dec 02, 2009
Larry Chandler
    President:
  • 1,149 Answers
Hi:
One thing to try is to connect your Inspiron up to an external monitor. You can plug in any kind of monitor, but you might have to toggle to the external mode:
Hold down your function key, then hit the LCD/CRT key. If you have a good display on an external monitor, then you are going to need either a LCD inverter or new LCD. They are not too hard to swap out, the inverter costs about $15,it is mounted in the lid, below the LCD, and the replacement LCD about $80.
Posted on Dec 01, 2009
Testimonial: "Thank you so much for your suggestion. You're awesome!!"
2helpful
Vizio e500ib1 50"smart tv power on light then that goes out. has 5volt stand by only, there are voltage that come up but fade out. screen is black no sound. was working great perfect picture,
Do you have voltage (3.5V) on the PSON terminal when you push the start button on the TV...if you don't its the main board that has failed
Dell Inspiron Black Screen
more likely a fault with the wiring or an invertor board problem
1helpful
I have dell inspiron 1200 that unexpectedly goes into sleep mode.
Go to Start Menu>Settings>Control Panel> PowerOptions
Then go to the Advanced tab, Under Power Buttons, make sure "When I press the Power Button" and "When I press the sleep Button" are set to "Do Nothing"
NO PICTURE CAN HEAR SOUND BUT SCREEN BLACK
If the picture faded over time and then went out completely....you have a bad digital main board. Hope this helps.
Presario 1200 locks up and the screen fades to white
Sounds like the machine is overheating. Check to see if the cooling fan is working properly and comeing on at regular intervals. It could just need a good cleaning. I had a similar machine with the same problem, turned out to be a hair wrapped in the fan. Your's may or may not be this simple, you may need to replace the fan. If this doesn't fix it let me know and we'll take a different approach.
Dell inspiron 8500 notebook monitor died
replace screen easy to pop put and in buy the part u need on ebay ok when your ready ill walk u throw it all mark me as fix ya then add me to yahoo mssg nick_helpap ok
Inspiron 6000 black screen
I think your talking about your screen fading out.
This is normal. LCD screens do slowly fade out over time. They have a life span.....If this is indeed the problem, then you have 2 choices.
1) Get the screen replaced.
2) Get a new laptop.
My advice would be getting a new laptop as the prices are getting lower every day. Most likely this is the cheaper option.
2answers
Dell inspiron 1200 need to replace lcd
Have you priced a repalcement screen yet?? you may not want to bother as get another unit and transfer all your stuff over to a newer puter. Good Luck
Open Questions:
See all Dell Inspiron 1200 Notebook Questions
Dell Inspiron 1200 Notebook Logo
Ekse
Mandeep  Singh
Mandeep Singh
Michael Thomas
Michael Thomas
